  1. noorbeast
    150,037Coins
    +10,993 / 54 / -2
    The lighter you can keep things the better.
    What brand is the seat, it does not have the usual logos splashed over it?
  2. Leo Burton
    Leo Burton Active Member
    London, UK
    2,625Coins
    Did your last rig consist of a GameRacer Pro cockpit? Or did you build your own?
  3. SilentChill
    20,567Coins
    It was a game racer pro I just put on top of the pivot and yeah that was that ;)
    @noorbeast it was off ebay and cheap only £129 delivered it's unbranded so no logos
  4. SilentChill
    20,567Coins
    Few more bits added time for mounting the rest of the motors 20150606_144659.jpg
    • Like Like x 8
  5. SilentChill
    20,567Coins
    All the motors are now in position :) 20150606_212733.jpg
    • Like Like x 10
  6. SilentChill
    20,567Coins
    Ok a lot of faffing about making levers and drilling holes.
    Got the Base shape of the platform done and think I got my measurements all right for the arms will have to see when I eventually mount it.
    20150607_220901.jpg 20150607_220924.jpg 20150607_220854.jpg 20150607_220958.jpg
    • Like Like x 12
  7. Leo Burton
    London, UK
    2,625Coins
    This is coming together so quick! I'm super impressed at the speed you're getting this done. Can't wait to see it finished!
  8. SilentChill
    20,567Coins
    @Leo Burton yes I like to get stuff done quick as possible as I have no patience, I will hopefully have it up and moving by the end of the week. At least that's my plan :)
    • Optimistic Optimistic x 1
  9. Pit
    30,463Coins
    hehe, the optimistic button with best wishes to you :)
  10. SeatTime
    28,320Coins
    Coming along well, I certainly need some patience, as I'm making yet further modifications/improvements (now waiting for more parts) to my DIY actuators before I nail down the design and building all the others (back to a 6DOF - explain more later in my thread). How wide is your base - its hard to tell?
  11. BlazinH
    16,642Coins
    I think wood is an excellent building material when it is designed properly so the stresses put on it don't end up tearing it apart! And it is easily cut and milled also making it faster to build with than steel; especially if you're not a welder! ;) Keep up the good work @SilentChill! :thumbs
  12. tronicgr
    tronicgr
    Make sure that you use lots of 47000uF 50v caps in parallel with each PSU. Then it might work...
  13. SilentChill
    20,567Coins
    @SeatTime the Base is 1370mm wide. Glad you have gone back to 6DOF can't wait to see you finally start building it
    Thanks @BlazinH there are lots of threaded bar holding it together along with screws :)
    @tronicgr hopefully I won't need the extra caps but will keep it in mind if it trips out.
  14. SilentChill
    20,567Coins
    Ok another quick update.
    Laid out where stuff gonna be there or there abouts.
    Get it all wired up fastened down and may be able to give it a test :eek:
    Probably will box it all in once I have it all up and running and it doesn't fall to pieces.
    I will probably will have to change a few things to firm and stiffen it up a bit once I have it working.
    Oh and make brackets for the hall pots can't forget those pesky things :thumbs
    • Like Like x 9
  15. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Loving it :grin
    Is that M12 threaded rod you are using?
    • Old Old x 1
  16. SilentChill
    20,567Coins
    Yes @Paul Shortland used it on my 3DOF and never ever had a problem with it and its cheap as chips from screwfix :)
  17. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Yes was just there buying some M10 :thumbs (Bent my first one)
    Interesting that 6 x M12 will take the weight, one day I will try it!
  18. Leo Burton
    London, UK
    2,625Coins
    Holy Crap! A 6 Dof Gimbal in 3 days! I can't believe it.
    Loving the daily updates. ;)
    Keep it going!
  19. Wanegain
    Wanegain Active Member
    Bruxelles
    1,993Coins
    :eek:
    How can you be so fast o_O ??
    Incredible work !!
    Can't wait for the first video :popcorn
    Good luck !!:D
  20. tronicgr
    tronicgr
    Obviously he is not married...
    • Agree Agree x 3
    • Funny Funny x 3
