prilad
Richard Burns Rally (SSE) plugin 2.0.0.0
SimTools game plugin for Richard Burns Rally (SSE version)
  1. prilad
    Dubna, Russia
    9,671Coins
    3DOF, DC motor, Arduino, 4DOF
    prilad updated Richard Burns Rally (SSE) plugin with a new update entry:
    Richard Burns Rally (SSE) plugin with DashApp support
    Read the rest of this update entry...
  2. prilad
    Dubna, Russia
    9,671Coins
    I've fixed Dash Data trouble (I hope)
  3. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    thanks for your work on the Plugin and also adding the new features like Handbrake and Boost etc.
    I just tried it with my dashboard.
    But its the needle isn't going very smooth. Worked better with Soraz exe.
    I don't know if this has something todo with the plugin or my code. But i think its my bad code. :)
  4. prilad
    Dubna, Russia
    9,671Coins
    Sorry, but I don't understand - what value do you need to make "smooth"? Plugin only reads data from game and sends it to SimTools... Without any "transformation"...
  5. soraz
    soraz Member
    Noale VE, Italia
    5,165Coins
    i test on my dual-core pc game, simtools and game dash, but see a normal response time of value in game dash.
    also reported by @tombo i think the problem could be his code.
  6. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    I don't know what was the problem. But the behavior of both outputs was very different on my motors. I left arduino Code and gamdash alculation untouched. Now i modified it and it works a lot better wih Pirlads Plugin.
    Thanks you two so much i waitet so long for dashboardoutput on Rbr =)
  7. Chosa4
    Chosa4 Chosa4
    Photographer
    Lusaka, Zambia
    257Coins
    Hello gentlemen, thanks for finding the solution. You won't believe how happy that makes me.
    I will try it out soon. I have been in and out of hospital nursing my daughter. She had Pneumonia, but fine now though it seems I caught something in the hospital myself as I have been sick with Cough and sinusitis. But this good news is worth getting out of bed for.
    Thanks for the solution.
  8. Agosky
    Agosky New Member SimAxe Beta Tester Gold Contributor
    Finland
    307Coins
    Thanks for this plugin!
    There was a discussion earlier about this plugin and RSRBR. I can confirm it reads values from game using RBR 1.02SSE and RSRBR 2015.
  9. Rainer
    Rainer New Member
    Sweden
    250Coins
    TC.jpg GE.jpg GMPE.jpg JRKCUMOTOR.jpg JRKCUPID.jpg Thanks for this great plugin!
    I have a problem though: I don´t get any game data input on the surge axis and no surge motion? All other axis´work perfectly.
    Here som screenshots to show values captured in tuning center and my settings in game engine and game manager profile editor. Main level is at 100%.
    As you can see all other axis´give input but surge is at 0.
    I´ll also show my motor and PID settings in the JRK configuration utility although I don´t think that´s the culprit here.
    My hardware i JRK´s, ZYT-90 motors and bourns 360 deg pots in a seatmover setup. I´ve prepared everything for traction loss but chose to get the seatmover up and running before proceeding to that.
    Thanks in advance! :)
  10. prilad
    Dubna, Russia
    9,671Coins
  11. Rainer
    Rainer New Member
    Sweden
    250Coins
  12. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
    Hi @prilad. A few persons have problem with pathing the game. Me too. I have RBR installed on L: drive, patch 1.02 is applied. Message is: "the selected Path is Not Valid for Patching". Can You help please?
  13. prilad
    Dubna, Russia
    9,671Coins
    @gorzasty, are you sure you try to patch RichardBurnsRally_SSE.exe? Can you write here full path to the game? And try to reinstall game to "C:" drive and patch it.
  14. stepus
    stepus New Member
    Czech Republic
    158Coins
    Hi, i have same problem, i installed RBR, and applied patch 1.01 and then 1.02. I have in i RBR folder executable RichardBurnsRally_SSE.exe and in the game manager when i trying to patch game it show message : the selected Path is Not Valid for Patching. Thanks for your help
  15. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Even if it is an old game I really like RBR and I play often with it (RSBR).
    I think it is still the best rally game in term of physics (I don't like the physic and the feeling in Dirt)
    I have a 3 DOF (just added a new actuator for traction loss)
    Is it possible to use traction loss in RBR ?
    I saw in the plugin traction loss is not in extra1 like other games.
    Maybe It is possible to do something with a little bit of Yaw and Sway assigned to the third Axis ?
    My 3 screens don't move, so I just want a little effect when losing the rear of the car.
    Is there a way to do that ?
    Thanks :D
  16. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Hello prilad, there is hope to update with traction loss in this game? thanks, good job
  17. stepus
    stepus New Member
    Czech Republic
    158Coins
    i thing i found bug in yours plugin, its in surge movement, when i accelerate simulator is going up, and in braking down, thats ok. But when a car rotate a 180 degreses on map it working conversely, when i accelerate car simulator going down and when braking it goes up. Seems like a compass is confusing this value. Or is it my mistake and plugin is OK ? thanks for your help :)
    Sorry for my english, Iam a Czech.
  18. noorbeast
    154,570Coins
    +11,190 / 57 / -2
    Is that on a particular map or all maps?
  19. stepus
    stepus New Member
    Czech Republic
    158Coins
    i am using same settings for WRC and GTR game and axes working perfect, but on RBR is a bug in plugin i thing. Yes, i had tested, driving school ( something like parking lot ) and some races in FR. So i thing others maps cannot affect this bug.
  20. fzxj520
    fzxj520 Active Member
    1,341Coins
    prilad Hello! Thank you very much work!
    After my test, I found some abnormal surge, the surge of direction is not a car coordinate their movement, but the movement to coordinate world system?
    I do not know if only I had this problem.
    The following is a case of the test: The green arrow is the direction of car travel, the direction of the red arrow is the surge, the length of the red arrow is the intensity of the surge.
    A few days later I again run rbr test results returned to normal. Really pleasing.
    Now changed and does not change the regional language is set to test, are not following errors.
    I think the problem might be due to an error the operating system, you need to turn off the power, restart the system down.
