Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. BlazinH
    16,671Coins
    To standardize outputs from different game titles, gamedash usually displays speed in meters per second (37km/h = 37,000 meters per hour / 60 = 617 meters per minute / 60 = 10 meters per second).
    • Useful Useful x 2
  2. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
    thanks for your answere it was very usefull. I've testet a lot with this new info.
    Since I am do much testing with Dashboards at the moment, excuse me for all of my Questions. Maybe they are a little bit stupid, because I'm very new to that coding Stuff and Gamedash.
    I have another Problem now. I get the right value on the dashboard now after using this formula in Gamedash
    Code:
    Math * 60
    Math * 60
    Math / 1000
    Round 0
    Pad 1 0
    TOCHR
    Because my code takes Km/h 0-255 as char value and than map it. With Rbr it works all good now. Everything is working fast and smooth. But with Dirt rally i got some Problems. But only with the Speed.
    I tried that calculating on Arduino and Gamedash, no difference. The needle only move in single steps.
    I thought the hole day about it and came to no result. A few minutes ago i tried again and maybe have found whats wrong. But i don't know if this is the failure or not.
    If i compare this to RBR which outputs speed in KM/H the Values are changing very fast, so i get a smooth needle movement.
    I take my values from above post with 0-37 km/h which is 10m/s.
    I only get new data at 1,2,3..10 m/s . 1m/s=3,6km/h 2m/s=7,2km/h and if its making a huge step, incase of fast accelerating in game, it is more so the steps are bigger.
    so I'm missing c.a 4km/h where the data is send to arduino and the nedle only moves in this steps.
    It's hard for me to explain and i hope you can understand what i mean.
    Sorry if this is the wrong thread for this, but i absolutly don't know what to do. :sos
  3. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
    i think that it should be
    Math * 3.6 (one line)
    you say that 37km/h is inside game and game dash shows 10 so you have to multiply 10 with 3.6
    {3.6=(60*60/1000)} so you can get almost 37km/h
  4. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
    I tried this also before, but it's the wrong calculation.
    Transforming the value isn't the issue.
    I will try to descripe it a little bit better this time, because i can't find any good screencapture software for free.
    If i take the first stage in list and first car which is Mini Cooper.
    At beginning, i give full power until the end of the gear is reached. (37km/h // 10m/s)
    My code is pretty much the same found in racing mat's thread. It sends a position value to the switec motors if a new value is avalibe on serial port. With Rpm this happens very fast, because the values change very fast like you can see in Gamedash input). But with speed it happens very slow. So the motor get not updated fast enough and the movement isn't very smooth.
    So it doesn't matter what calculations i do with the value, because i only get a new calculated position value if the Input will change. (which is m/s and that happens very slow)
    I hope you can understand it better this time.
  5. nff
    nff New Member
    portugal
    - 93Coins
    SCN5, SCN6
    Hi, me again...tried the sugestions, unistalled simtools, re-installed..everything OK, EXCEPT when i copy the dirt plugin!...
    I'm begining to get despaired...it only worked in 1st version, then i probably did something wrong, don't know..after that never worked, and crashes the simtools game manager/engine...i'll try to post a printscreen of the error...PLEASE HELP!
  6. value1
    15,082Coins
    @nff Please go to C:\users\leontec\AppData\Local\SimTools\GamePlugins
    Right-click on DirtRally_Plugin.dll and select Properties.
    A dialog box opens:
    Check if there is a button "Unblock" and unblock the file.
    Hope this helps
  7. yobuddy
    51,239Coins
    Hi @nff,
    Did you use the plugin updater to install the plugin?
    I ask because it should automatically unblock files.
  8. nff
    nff New Member
    portugal
    - 93Coins
    SCN5, SCN6
    IT worked allright!!...you're a genious...can't thank you enough!
  9. nff
    nff New Member
    portugal
    - 93Coins
    SCN5, SCN6
    Hi yobuddy, no i hadn't seen that, but now everything is OK folowing the instructions of value1..for the future i'll use the plugin updater..THANKS
    Off topic, i sent you PM regarding simtools license, did you see it? THANKS
  10. value1
    15,082Coins
  11. Atlas974
    Atlas974 old school
    Physics chemestry
    Reunion island
    358Coins
    Hi, since lastest dirt rally update (tarmac terror), motion got weird.
    Sometimes looks like telemetry is offset in time: i dont get any motion since 15-20 sec in game and then it come and go without reasons.
    Sometimes i got motion for the whole part of the race, and no motion at all after for another one...
    Sometimes when i quit the race looks like all motion telemetry is "played" to simtool in a very tiny moment of time.
    Tried other game and they play fine, tried remove patch and patch again, no effect. Got win 7 64 with patch going into the saved game like asked when trying to patch.
  12. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Hi I'm still on the second plugin update the one before the fixed RPMx10
    No problem with Tarmac Terrors update on that version, hope you get it sorted
  13. SilentChill
    20,596Coins
    My Telemetry has suddenely stopped working dont know if the update today has screwed it up or not ?? Other games are working fine so something must be wrong with this, anyone else having problems ??
  14. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    @SilentChill Will test later, got the update but not had time to test it yet :(
    EDIT Nop no movement the change log says they made changes to the telemetry data for D Box
    So I guess that caused a problem.
  15. SilentChill
    20,596Coins
  16. value1
    15,082Coins
    • Winner Winner x 3
  17. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    @value1 wow that was fast Thank you !!
  18. stamer57
    stamer57 Member
    963Coins
    Thank you for the update
  19. SilentChill
    20,596Coins
    Holy shit thanks @value1 what would we do without you !!!!!
  20. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Ok all tested and working got great motion again and my GI Max still works too thanks again :thumbs:cheers;)
