Motor Selection ?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Jason Currington, Sep 1, 2015.
  1. bsft
    As this has been disagreed to by 2 members, I am not going to modify it, but leave it as is. @Jason Currington , I shall leave this up to you. Enjoy your sim building. You are welcome to choose the control boards you wish, and there is help from both sides in getting them going.
    Dave out.
  2. Jason Currington
    Jason Currington Member
    537Coins
    Motion platform
    would these motors be able to sustain many hours of play at once ? or is overkill in this case a good thing being that I am heavy ? I have no problem spending the money to make it work correctly. rather that than having to redesign the whole rig
  3. Jason Currington
    537Coins
    Motion platform
    Thanks for all your input Dave really appreciate your time and effort :D
    • Friendly Friendly x 2
  4. Jason Currington
    537Coins
    Motion platform
    also not too familiar with digital design and drafting . could you suggest a program that a newb could start with to lay out plans
  5. bsft
    I dont have plans as such, but a basic sketch to start with for a shoulder mount seat mover
    With your weight Id suggest set motor rod arms back at 20 deg and 20 deg to the side. @Nick Moxley , but chance do you have a sketch to share?
    Just make a frame for the seat and add extra size for the bottom
    The motors and gearboxes will survive if properly put in place. @eaorobbie and @Nick Moxley has been thrashing the crap out of their motors and I used them on simulators for commercial use and since I sold the simulators, they are still going.
    Anything will fail if incorrectly used, as several people found out.
    The motors Nick linked you to will do the job just fine. Set them up right and thrash hard.
    Dave.
    EDIT, once a seat is found suitable, a frame design can be worked out from there. Its not complicated, just the right measurements.
    153,866Coins
    +11,152 / 57 / -2
    Here is a link to various design software applications, including how to hook a Google Sketchup model to SimTools and drive it with a real game: http://www.xsimulator.net/community/faq/design-software.114/
  7. Jason Currington
    537Coins
    Motion platform
    ok sounds good
    I will look for a seat... Sparco racing seat or something similar ?
  8. Historiker
    9,205Coins
    Don't worry Jason, I am bigger than you (6'4 @ 350lbs) and mine tosses me around like a rag doll. My wife made me install seat belts! :)
  9. Jason Currington
    537Coins
    Motion platform
    haha good to know.. Good think my wife will probably divorce me over this thing.... of course joking (or am I :D)
    I just finished a model in sketch how can I post it here to get some input on design. I would like all to see so I can make some changes and such
    153,866Coins
    +11,152 / 57 / -2
    In Sketchup you go to File->Export->2D Graphic then give your image a name, save it to your computer and then upload it here as an image in your post.
  11. Jason Currington
    537Coins
    Motion platform
    First attempt at using drafting program but here is the general idea of the chair
    153,866Coins
    +11,152 / 57 / -2
    That is a very useful start.
    Can I clarify what you have in mind to connect the motor to the bottom platform for traction loss, is it a cable, chain, rod or something else you have in mind?
  13. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    • Useful Useful x 2
  14. Jason Currington
    537Coins
    Motion platform
    Yes. I was thinking chain. Seems you can get more travel out off it than a linkage and level setup
    153,866Coins
    +11,152 / 57 / -2
    What travel are you planning, others have gone for 300mm total or less?
  16. Jason Currington
    537Coins
    Motion platform
    Guess I don't know what the standard Tra el would be.... what should I be aiming for. Also should my controls be stationary or mounted to the Sim ?
  17. Jason Currington
    537Coins
    Motion platform
    So about my spelling...... use phone a lot and auto correct drives my f*÷*#£÷&! Nuts
  18. noorbeast
    153,866Coins
    +11,152 / 57 / -2
    Follow in the footsteps of what others have done: http://www.xsimulator.net/community/faq/traction-loss.174/
    It is a seat shaker design if the controls are separate and a full frame design if the controls move with the sim. Both designs have their advocates, see here for a current discussion on the topic: http://www.xsimulator.net/community/threads/what-the-ideal-motion-system-for-a-racing-sim.7298/
  19. Jason Currington
    537Coins
    Motion platform
    Ok so motor 1 and 2 are shoulder mount. And 3 is tracking loss, do I need a 4th for heave function ? and if so how do I setup heave with a ujoint style support ?
  20. speedy
    Alexandria , Egypt
    7,948Coins
