X-Sim support for SCN5 actuators
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by yobuddy, Jul 18, 2008.
Thread Status:
Not open for further replies.
  1. charlypro
    charlypro New Member
    California
    0Coins
    Hey gus no worry for the TBVST software I can find that in case that we will need, so that is no an the problem.
    Charly
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    I am pretty sure that this software is licensed, and we dont want to use software for which we dont own a proper license.
    Besides that, we wont need it anyway.
    Regards
    Christian
  3. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Hey, Ego.
    I know it is funnier to build it, but would these adapters work?
    Two of them, actually?
    http://ekmmetering.com/EKM_Metering/Con ... pters.html
    Would x-sim work with them as well?
    Thanks.
    Erick
  4. egoexpress
    421Coins
    No, I dont think they will work.
    The readme of its driver says:
    And we need the possibility to assign names, to differ between left and right actuator.
    But it would work for Chris J I think.
    Regards
    Christian
  5. egoexpress
    421Coins
    4 donators more would reduce the individual donation to 30$ instead of 40$. :clapgirl:
  6. zapan
    zapan New Member
    Spain - Barcelona
    11Coins
    Hello guys, :hi:
    An excellent forum you have. I'm Oscar from Spain and you have a new donator here :thbup:
  7. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Hum... Interesting...
    I have already had two identical USB devices, with same name on Windows Devices List, but that would be seem separately inside the games (just to name it, ECCI USB Controller).
    I do see that changing the USB port will change the config.
    Then, my question is... Will we be able to configure x-Sim to tell him which is the left and right actuator controller?
    Cheers,
    Erick
  8. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    I know what you mean... ;D
  9. yobuddy
    51,000Coins
    Ok, I know I’m getting ahead of myself with this one. But I think we should have a solution that will enable us to add more DOF’s in the future. For example, a simple platform could be built to add YAW to any SimForceGT platform.
    Anyway, it’s just a thought.
  10. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Cool Buddy... But, would any SCN5 be able to deal with the weight of such rig?
  11. njracer
    njracer Member
    2Coins
    i love the idea of having yaw in the simulator, that would add a lot to it imo. definitely something i'm interested in :thbup:
    hey, does x-sim work with vista 64?
  12. Ringorumble
    Ringorumble Active Member
    190Coins
    Should work if you mount it on ball bearings or ? So the weight is not that much, it has just to pull and push
  13. tronicgr
    tronicgr
    I still believe that the best solution is FTDI.
    Just take a look on the next document and you will see why I insist! 8)
    FT232R_USB_to_RS485.pdf
    This is a design directly from FTDI!!!!!!!! :yippiee:
    And I can't believe that some companies took advantage if it to sell it so expensive (148Euro????):
    http://www.wut.de/e-38211-ww-daus-000.php
    We can make such ones, for less than 20 euro!!!! :mug1:
    Regards, Thanos
  14. charlypro
    California
    0Coins
    Sirnomane from what version of X-Sim you get that picture I cann't find USO and GUI like that let me know thank you.
  15. yobuddy
    51,000Coins
    Great find tronicgr, Looks like it will be pretty simple to build too.
    Will we have a jumper or dip-8 to select the actuator number?
  16. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Wow! That is amazing... I didn't know x-sim was so powerful, full of possible configurations!
    I will download it to start getting familiarized, it seems I will use it for a long time... :)
    Thanks noname!
  17. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    It is not so simple, it is huge mass to move around, accelerating and braking will be hard on the 10Kgf actuator, we are talking about 150-200Kg here... :(
  18. tronicgr
    tronicgr
    No, we can just reprogram the FT232R's VID and PID numbers!!! Sirnoname can define some default values for use in the x-sim and then we use them on our FTDI FT232R's to make them automatically recognizable from the x-sim software as devices and as seperate axis!!
    I just received my FT232R evaluation board and will try it as soon as I can. It a pity (from a point of view) that I'm having my summer vacations starting tomorrow, isolated in a Greek island away from electronics, computers and internet!!
    :shipwrecked: :yippiee: :swim:
    Regards, Thanos
  19. yobuddy
    51,000Coins
    Well, have a great vacation. I’m sure we’ll be here when you get back :cheers:
  20. tronicgr
    tronicgr
    I also found on my local electronics supplier the ADM485 chip for 2euro (same as MAX485).
    And if you combine it with the Breakout Board for FT232RL USB to Serial 9.50euro on the sparkfun site: http://www.sparkfun.com/commerce/produc ... cts_id=718
    And a small PCB and connectors... we can make this for less than 15euro...
    And we will have the advantage of custom VID/PID over it in the end.
    Sorry if I bug you all the time about it, but if we are to make it, we should do it right!
    Regards, Thanos
Thread Status:
