Gear Motors
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Sebj, Jul 8, 2015.
  1. Mazhar Salam
    Mazhar Salam Member
    Melbourne
    907Coins
    hi...
    I have done a lot of reading to choose the right motors for building my sim. A motor is manufactured in a trade off between torque and speed. that is higher the speed, less the torque and vice versa. Anyway, in our case, we need more torque. the motor mentioned here even though widely used by community members is configured exactly opposite to our purpose. That is it is running at about 3500 to 4000 rpm by compromising a lot of torque. when we add gears, again up to 50 percent of the torque is lost in transfer. However, the necessary torque required to move a sim in our case is achieved by pumping in more current in to the motor.
    the ideal motor will have a speed of maximum 1500 rpm with 10:1 gear box. Notice that both the above setup and this setup will have a final output speed of 150 rpm however, this setup can life upto twice the weight or use half the current required. You can simply check how much weight a system can lift by using the torque calculation formula.
    153,818Coins
    +11,150 / 57 / -2
    I think the 'ideal' motor and gearbox is challenging, as it relates to questions of design parameters, availability and actual cost.
  3. Sebj
    Sebj Active Member
    Canada
    492Coins
    I wanted to solicit some advice from the expert builders here on the forum :)
    Based on my preliminary design above, I want to determine what material to use for the frame. The obvious is steel but perhaps I need to use lighter weight material since its going to be traction loss frame that needs to be moved smoothly (with a 50:1 gear motor)
    If steel, how wide should/could the steel square bars be and how thick? I want to ensure there is no flex or bending.
    Lastly, what material to use for the castors to roll on for traction loss, should it be a half inch piece of steel or what else can I consider.
    thanks guys!
  4. bsft
    @Nick Moxley , what did you build your set up from? Maybe you can advise here
  5. Sebj
    Sebj Active Member
    Canada
    492Coins
    That setup is not yet built. I think steel is likely the senseable choice. Wondering what size rods others have used.
  6. bsft
    Ive use 25mm box steel on mine with no problem, and had 16mm MDF sheet screwed to the base to hold the tailshaft uni. It supported my 86 kg and 12 kg seat easy. And even survived 130 kg players
  7. WhiteGoblin
    WhiteGoblin Member
    California
    549Coins
    These are the motors I used for a full frame 2dof build. Includes feet, peripherals, etc. They work great with a short arm, I believe mine is 50-60 ctc.
