Project 2Dof
Discussion in 'DIY Motion Simulator Projects' started by Bordiin, Sep 30, 2015.
  1. bsft
    Do you have a photo of the front view of the seat ? I am not sure what you are asking
    EDIT, I am go to take a guess you are building according the the video and the design I had. I suggest dont go that way and look at the yellow desk racer mounts. The are a LOT higher than what you are up to I suspect.
  2. Blame73
    Blame73 Well-Known Member
    8,305Coins
    I would move to shoulder mount, as I lately did, cause otherwise wiper motors could easily overheat and suffer. Because of the better levers you will also feel little motions that now would be lost. I had the same project as you have now, and I regret I didn't do it sooner.
    This is my rig: http://www.xsimulator.net/community/threads/blame73s-2dof-seat-mover.6029/
  3. Bordiin
    Bordiin Active Member
    Brazil
    159Coins
    Hello @Blame73 i think about make the simulator like your, but i have some difficult to do mechanical adaptations, this is only a prototype, I'm building with things i found in my fathers garage kkk.
    @bsft I'm building following the many projects, i take the informations i think are better and put it all together. I have more difficult to make and to understand the mechanical part.
  4. Bordiin
    Brazil
    159Coins
    I want to change my motors, to Step motors i have to in my home, but the drive i have it doesn't accept the PWM,
    I need send (pulse and direction) It's possible program the arduino tho recive the signal the SimTools and send to my drive pulse and direction?
  5. Blame73
    8,305Coins
    I would suggest you turned your joint upside-down so that the ball joint would be closer to the seat, avoiding unwanted lateral movements
  6. Bordiin
    Brazil
    159Coins
    I'm not using the ball joint, Look i introduce the nut in my screw
  7. Nick Moxley
    Oh No No No....That will NOT work.
    Nor will those motor mounts.
    • Agree Agree x 4
  8. Bordiin
    Brazil
    159Coins
  9. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
  10. Bordiin
    Brazil
    159Coins
    i'll make changes in my project,
    so i send the question about
    Thank's all to help
  11. Nick Moxley
    I personally suggest the Rose style rod ends...part # SQ10-RS....i had a set of the cheaper rod ends that Tombo posted that failed real quick, Not to mention they lack in the "angle" department and might require spacer's of sorts.
    Motor mounts Defiantly need to be upgraded they unfortunately wouldn't last 5 minutes before bending out of shape and causing all sorts of issues.......For what its worth, The Small Angle Iron was able to be Twisted in how i have my motor's mounted, The Big Angle Obviously Not. Yes i have stronger motor's that you do, But thats beside the point. BUILD it Strong once, then you wont have to revisit these problems down the road.
    here you can see my Pivot point. the seat frame sits directly on top and is AS close as possible to the seat frame.
  12. bsft
    Motor mounts are too low. The motors will struggle, and if you decide to comment "thats what you did in your video, " , yes I did, however, it works better desk racer mount of shoulder mount.
  13. Nick Moxley
    This is the somewhat ideal setup for the motor's/Arm angles. Yes more angle would be slightly better, but somewhat marginal unless you have the real estate to play with. Your running wiper's so you need as MUCH mechanical leverage as possible to help the motor's.
  14. Bordiin
    Brazil
    159Coins
    I don't find the tip rod like you told @Nick Moxley but i find one look in the picture,
    now I'll adjust the base and the motors supports,
    @bsft I did a test with the motors in the base, but i had problems with the mechanical supports, so I stop the test and Start the new modifications
    152,535Coins
    +11,085 / 56 / -2
  16. Nick Moxley
    Those rod ends wont work like that, they will for sure need spacer's. The Rod ends need to have as Much "angle" travel as possible. The washers you have on currently will SEVERELY limit the angle's the rod ends can work with.
    This is WHY i suggest the SQ10-RS version's....they have Double the Angle of a standard Rod end.
    What is your plan for the motor mounts ? or i guess those will come with the redesign to accommodate some proper Angles on the arms ?
  17. Bordiin
    Brazil
    159Coins
    @Nick Moxley i'll follow @noorbeast suggestion, and put the cone spacers.
    The motors mounts i don't know yet. I'm thinking about it.
  18. bsft
    that bracket is NOT helping, the brackets will flex to much.
    either make proper brackets of build it like @Wanegain design.
    Im lost as to what or how your are trying to do things, so good luck doing whatever you are doing.
    Dave out.
  19. Nick Moxley
    I HIGHLY suggest you check out some of the Other Member's threads to see exactly how thing's are assembled and re enforced.
  20. Wanegain
    Wanegain Active Member
    Bruxelles
    2,008Coins
    I agree with @bsft, it will flex too much. You really need something stronger !
    If your structure is very rigid, you will enjoy longer your simulator but mostly you will enjoy the small effects that will not be absorbed by the flexibility of your system
