New XPID software for Arduino UNO/Mega and Sabertooth (with LCD !!)
Discussion in 'SimTools compatible interfaces' started by vthinsel, Apr 1, 2015.
  1. Pit
    30,497Coins
    Thanks @vthinsel for clearing out that. I think we are on the way, by sorting out these small issues the Sabertooth will become better and better. Still the annoying behavior mentioned in my thread should be solved and then nothing will stop anymore *optimistic* lol
  2. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,044Coins
    Arduino, 4DOF
    I'll double check that but I do not have specific directions. I'll try to reproduce it, so I can fix it.
    Meanwhile I have an almost ready-to-release version, with TFT.
    In this short video you can see it in action, and how tweaking the K (same as P, but wider scope) affects the motor response. You can even hear it : with a low K (0,1) the motor moves slowly and silently, and with K=1, the motor moves more quickly with more noise. You can also see that on the graphs (sorry for bad quality of the filming)
    3 lines are graphed per motor : RED = motor power, GREEN = current position, BLACK= target
    Of course, displaying the graphs has a small impact on responsiveness (graphing takes 4ms) but can help in tuning/troubleshooting : you can actually see noise on pots input. Maybe I'll make some zoom/autoscale and add graphs pages as per your requests :)
  3. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    @Pit , I have a possible improvement for your outstanding issue: in ParseCommand() can you replace the following code portion (use a constrain instead of a map which I thought would provide more accurate results)
    if (commandbuffer[0] == 'L') //Set motor 1 position to High and Low value 0 to 1023
    M1.setTarget ( (commandbuffer[1] * 256) + commandbuffer[2]);
    //M1.setTarget(map(M1.getTarget(), 0, 1023, M1.getMin(), M1.getMax()));
    M1.setTarget(constrain(M1.getTarget(), M1.getMin(), M1.getMax()));
    disable = 0;
    return;
    if (commandbuffer[0] == 'R') //Set motor 2 position to High and Low value 0 to 1023
    M2.setTarget((commandbuffer[1] * 256) + commandbuffer[2]);
    //M2.setTarget(map(M2.getTarget(), 0, 1023, M2.getMin(), M2.getMax()));
    M2.setTarget(constrain(M2.getTarget(), M2.getMin(), M2.getMax()));
    disable = 0;
    return;
    And also change the SetPWM with that one
    void SetPWM()
    M1.PIDUpdate();
    M2.PIDUpdate();
    if (disable == 0) {
    ST.motor(1, M1.getPower());
    ST.motor(2, M2.getPower());
    else {
    ST.motor(1, 0);
    ST.motor(2, 0);
    Of course, be carefull ;) with the walls.
    • Useful Useful x 2
  4. Pit
    30,497Coins
    @vthinsel any updates on your code? In the meantime I tried the SMC3 code however without success (no power output on the ST). Today I wanted to flash back the Ard and I got some strange behaviors, f.eg. the M1/M2 deadzone is 256 by default (?), I cannot save any new values...every time when I change the value it increases about 256 after saving. Ard UNo and MEGA are both "affected".
    Other values I can set as usually.
    Resetting the Ard does not change any values.
    Global values same behavior, these are the standard values after flashing:
    Read analog = 256(?)
    Feedback Max = 4281(?)
    Feedback Min = 255(?)
    etc.
    Either I got crazy or both Ards are damaged or whatever else happened. So I ask you kindly if there is any update. Or you would kindly bundle all the newest files because the first posting is out of date so other members will run into any issues about that as well.
    Thank you.
  5. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    Strange. The values have always been stored in the EEPROM at the same location. Maybe the values are out of the normal range, due to some other code and as I check for value range upon update...
    Did you try the reset function, in the global settings menu ? This should put default values in allowed range.
  6. Pit
    30,497Coins
    Hi, this works for me, now all values are within the standard range.
  7. Pit
    30,497Coins
    hmm, I uploaded XPID 311, updating now with 313 gives me the following error:
  8. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    I'll have to write a user guide someday..... I'll also update the code to address those strange values to make it more robust in such cases
  9. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    Hummm. I'm still running version 1.6.5
    I guess you upgraded to v1.6.6 recently. Maybe you should re-install libs, including the menubackend justto make sure.
  10. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    By the way, I have updated the first post with the latest version 1.13 (sorry, I didn't do it earlier).
    This version will be the last one to support LCD : next versions will be only for TFT+touchscreen and Arduino Mega. I will not add new features to this version; I'll only provide support and eventually bugfix it if needed (1.13a, 1.13b, ....)
    TFT dev is going smooth and I should have something ready soon. Get a TFT+LCD, it will be of some use soon :rolleyes:
  11. Pit
    30,497Coins
    Which model you would propose to buy?
    Thank your for the suggestions, I will downgrade the Arduino software and follow your steps.
    Apropos support - in case of new inexperienced Sabertooth users I could relieve you a little bit like I did on SMC3.
  12. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    Aren't you already running 1.13 ?
    Thanks for the support :)
  13. Pit
    30,497Coins
  14. Pit
    30,497Coins
    Version is 311...I am confused...the newest is 313, isn't it?
  15. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
  16. Pit
    30,497Coins
    Update: Arduino 1.6.5 did the job. Waiting for TFT touch screen...
  17. Pit
    30,497Coins
  18. vthinsel
    FRANCE
    6,044Coins
    Arduino, 4DOF
    Hum. This will be interesting. The one I use is 320*240. Yours is 240*400. So hopefully the last 80 lines will not be used (I use it in portait mode). I just hope it uses the same lib and has the same chipset....
  19. Pit
    30,497Coins
    OMG I am stupid - the libraries! I forgot that point.
    PS: i canceled the order.
  20. Pit
    30,497Coins
    @vthinsel yuppie :)
    BTW the display is not really sticked on the shield ?!? I have to fix it before the display will snap
