value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. noorbeast
    152,977Coins
    +11,116 / 56 / -2
    In the Tuning Center un-check the tick in the box next to the name of the axis you want to manually enter a value for, say Roll, you can then manually enter Max and Min values all the way down to 0.01.
    The values must be entered like this, 0.5 not like this 0,5 as a decimal point is the recognized deliminator.
  2. AlexinChina
    AlexinChina Member
    China
    371Coins
    It's interesting! I cannot download "cheat engine",can you email to me ? Thank U!
  3. Pit
    30,502Coins
    Hi @value1 I have bought the non steam version of No Limits 2 - the telemetry extension does not seem to work here...
    PS: there is an update, I will install it first, did not see it.
  4. value1
    14,175Coins
    The plugin has been tested with the steam and with the stand-alone version and should work.
  5. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    hello i am trying to download /buy with coins this plugin and i cant . It asks me to buy a week worth downloads ???
    is this a bug ?
    thanks
    152,977Coins
    +11,116 / 56 / -2
    No it is not a bug, you can use your virtual coins to get the week long access package here: http://www.xsimulator.net/community/shop/
    Once you do that you will then be able to download all plugins during the week.
  7. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    hello i cant get this plugin to work on windows 7 x64 + steam?
    is the patching a bit special to do . i patch c:/program file x86/steam/steamapp/common files/ no limits2
    it looks there is some conection but no motion
    tuning center sho so data but the data freeze not changing
    any advice?
  8. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    try patching to the folder \NoLimits 2\64bit\
    Thats the path in the non steam version
    152,977Coins
    +11,116 / 56 / -2
    Just checking, have you added the --telemetry flag to the Steam launcher as per here: http://www.xsimulator.net/community...ter-simulation-plugin.4777/page-11#post-85890
  10. MatheusHA
    MatheusHA New Member
    Brasil
    196Coins
    2DOF, DC motor, AC motor, Arduino
    For how many time can I use a plugin after the end of my download package?
    152,977Coins
    +11,116 / 56 / -2
  12. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
  13. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Patched the game on both computers, add the --telemetry, game running shows in blue, remote computer which works with other games shows 0 in tuning center. 2.2.0.3 version.
  14. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    I'm having troubles with making this work, I have no telemetry data.
    - Game is non-Steam latest version 2.2.0.9
    - Telemetry tag is added in the NL2 shortcut like this
    - I've tried patching main NL2 folder, I get "connected" but no data in Tuning Center, Virtual Axis not moving too
    - I've tried patching "64-bit" folder, same thing, connected but no data
    - Program is allowed in Firewall
    Any other suggestions?
    Anyone has it working with nonSteam version?
    EDIT: It's working, see 2 posts below.
    152,977Coins
    +11,116 / 56 / -2
  16. prodigy
    Croatia
    6,698Coins
    OK, I got it working.
    Since I've bought the game today and received a download link, I thought I've downloaded latest version, but I didn't. Also, the ingame auto-update check was enabled, but it still didn't ask me to update after several game starts.
    So I've found out that the latest version was 2.1.1.1 where Telemetry server was added.
    After updating I got the data and motion.
    But also, as stated in some posts above, once you exit the game, you need to exit Game Engine and Manager too and start all programs again, otherwise, it won't work.
    EDIT: Just the Game Manager needs to be closed and open again.
  17. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    I tried this plugin with no limits v1.8(updated after v1.6). and patched in game manager(administrator..) but no msg(patch successful) came up. anyway, run the no limits simulator. game manager shows just connected, not game running. of course no motion in the game.. could you please help me??
  18. value1
    14,175Coins
    Please use a previous version (e.g. version 2.0.8664.18) because version 2.2.0.2 does not work with NLS V1
  19. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    I installed no limits 2, and now game manager says "game running" but still no movements... after searching up, I created shortcut with flag; -telemetry, but there is nothing..
    can you help me again??
  20. value1
    14,175Coins
    Have you realised that it's "--telemetry" not "-telemetry" (two hyphen, not one)
