final year project: 2DOF seat mover motion rig :)
Discussion in 'DIY Motion Simulator Projects' started by IJOJOI, Oct 20, 2015.
  1. Nick Moxley
    No body else mentioned it which im kinda surprised about but that seat frame is very much under supported. Unless your using a Super Thick Base plate you will have some big time flex. Highly suggest you go back to the drawing board and make an actual frame of 80-20 rather than the Single Spine you have in the render.
  2. bsft
    A bit of 18mm thick plywood should fix it
  3. Nick Moxley
    3/4" ply would also Flex in that situation.
  4. bsft
    Ok, maybe Ive just had success in my builds. For all of them I build a 25mm box steel frame under the seat and screw a sheet of 16mm MDF to it , then I bolt the uni joint to it. Its never flexed or given me issues, be it full frame or seat mover.
  5. Nick Moxley
    Did you look at his render ?
  6. bsft
    Yes I did, hence a suggestion of a steel box frame like I added. Because his rendered frame would flex like a bastard.
    Unless I missed something..........
  7. bsft
    Its not too clear as there is a bag of cement in the way, but my seat mover frame is 25mm x 25mm steel with 16mm MDF screwed to the top of it, and the uni joint bolts to it. Heres some other pics of frames as well.
    2014-01-21 10.21.02.jpg 2014-01-21 12.26.10.jpg 2013-08-06 12.55.09.jpg IMG_20120707_103932.jpg
    This has never flexed on me at all. Maybe @IJOJOI can implement something like this in the design, because, as you say, his rendered design, if built, will flex like crazy
  8. IJOJOI
    IJOJOI Member
    Austria
    523Coins
    SCN5
    I just ran my 3D through Finite Elements, and it seems like it is moving quite a bit...
    I'll all a frame to it and see how it will change it.
    Thank you very much for advice @bsft, totally forgot about that!
  9. Nick Moxley
    Cough Cough, 8 posts Up.......pretty sure my name isn't Dave. ;)
  10. bsft
    ok then Harry,
  11. IJOJOI
    IJOJOI Member
    Austria
    523Coins
    SCN5
  12. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    815Coins
    2DOF, SCN5
    I eliminated the seat frame all together by using a premolded poly seat from summit racing. Added padding and a leather cover. Cost back then was around $70. Bolted my universal to a piece of 3/4 plywood that bolted to the botton of the seat. Bolted a cross bar through the upper back of seat for the actuators. 7yrs later, never had a problem. http://www.summitracing.com/parts/sum-g2100
  13. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I think they will work great for a seat mover, check anyway for a 2ton version, it is almost the same in price.
    Don't hesitate to ask if you need any help.
  14. bsft
    Interesting, granted hes having issues getting the PGsaw type of motors, but for a full frame, they do just fine on one of my former sims
  15. IJOJOI
    IJOJOI Member
    Austria
    523Coins
    SCN5
    @bsft
    Hello!
    We are now in the final stages of design, and will start putting all together next week.
    I wanted to thank you again for your kind donation so that I was able to download Simtools and so on!
    I am in the middle of writing the necessary plugin now ;)
    A forum Member linked me a your SETUP guide back then, but it's not available anymore :(
    Do you know why or where I can find it?
    This was the link: http://www.xsimulator.net/community...-set-up-simtools-jrks-and-write-profiles.112/
    Best Regards
    Johannes
  16. noorbeast
    152,676Coins
    +11,089 / 56 / -2
    Nice to hear your project is still progressing.
    To do the initial JRK set up follow @eaorobbie advice: http://www.xsimulator.net/community/faq/jrk-setup-guide-eaorobbie.14/
    To calibrate the JRK follow @Avenga76 procedure and video guide found here: http://www.xsimulator.net/community/faq/practical-examples-video-tutorial-to-jrk-pid-tuning.225/
    When the JRK PID is done you can then move on to creating and configuring SimTools motion profiles, there is a whole section of handy hints in the FAQs: http://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    The basic steps for creating a motion profile are here, just do one force at a time, refine and repeat, then mix them all and refine: http://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    If you are not sure of anything just ask and members will help you out.
  17. IJOJOI
    IJOJOI Member
    Austria
    523Coins
    SCN5
    Actually we are at the finish line ;)
    We still to design a arm for the h-shifter, but everything else is basically finished.
    I didn't update the thread, because most of the stuff done lately was calculation.
    We needed to know the exact price and all the parts, which basically resulted in very slow progress,
    since we had do assemble all the screws and nuts.
    Furthermore more than 15 hours went into giving each part the right parameters. (eg. material, strengh etc.)
    There are still a few small things I need to adress like the lever and how it's connected to the rods.
  18. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    Here's how mine will be attached. It might help.
    Below is a pic of the shafts. The round tube piece will have the lever welded to it. The lever will basically be shaped like a flat spoon. So the round end will be welded on and the lever will come out from there and will have holes at 40mm, 60mm, and 80mm, from the center of the round part.
    I have SQ10-RS rod ends, which are screwed onto an M10 threaded bar which runs through a custom made fitting which fits inside a 19mm x 25mm carbon twill weave rod. The other end is basically the same thing and the shoulder mount is just a flat 55mm steel rectangle welded to the frame with a hole in it. I decided to use the threaded bar all the way through the carbon from top to button as a sort of tensioner. It'll help to keep the fittings at each end in a perfect position to reduce flex in the rods.
  19. IJOJOI
    IJOJOI Member
    Austria
    523Coins
    SCN5
    So here is the promised update guys ;)
    Enjoy
    4k_ganz_0.png 4k_ganz_1.png FAHRSIMULATOR.jpg FAHRSIMULATOR_0.jpg FAHRSIMULATOR_1.jpg
    152,676Coins
    +11,089 / 56 / -2
