value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    I didnt know that.. So I tried with 2 hyphen.. But same... Uhm.. Seems to get no motion data from the game...
    I am using winfows 10 and FSX is working well with simtools..
  2. Alex Swann
    Alex Swann New Member
    - 51Coins
    I'm also having the same problem. I have the steam version and I tried patching the no limits 2 folder and the 64bit folder with no "patch installed" message. I also added the --telemetry in the steam launcher and still no luck. Game manager says Game Running when I start the game but no motion. Any help would be greatly appreciated.
    153,836Coins
    +11,151 / 57 / -2
    Have you tried running Game Manager as admin and then try patching NL2?
  4. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    @hb kim the current version of the game appears to be 2.2.0.3. Therefore the plug in won't work until it's also updated.
    Mike
  5. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    been like this for a while not sure i can figure it out but my check out the plugin tutorial
  6. Alex Swann
    - 51Coins
    Ok I got it working, I had to run Game Manager as administer and install the patch. Thanks for the help!
  7. donald
    donald Old Simer New Guys
    Free Job People
    3Coins
    Motion platform, 6DOF
    @value1 hello value1, i just get an nolimit2 on stream, the version shows 2.2.1.2 64bit. but there is Strange situation,there is no motion data(i already check in the tuning center). everything is fine( install plugin) when i start the game before. but when the game is start. it pop a message on background "motion not supported". i try everyting i can do , run the gamemanage and NL2 with admin, add --telemetry on start option. my "SteamLibrary" is not in the default installation position,i install all the steam game in F:/ , is that should have a problme with the plugin runing? 307613499252165166.jpg 152214776916555667.jpg 221383415616215918.jpg 832910552387348755.jpg
  8. donald
    Free Job People
    3Coins
    more information is i m test NL2 in windows 7 x64 + steam and win8.1, still the same problme. and i v try to patch in NL2/64bit floder. and restart the gamemanage, it is the same too.....
  9. value1
    14,239Coins
    @donald
    Are you using the latest version of the plugin?
  10. AceOfSpies
    19,614Coins
    Hi @donald if you are using the latest plugin, and running the game from Steam, you must patch to the programx86/steam/steamapps/common/nls2, folder.
  11. donald
    Free Job People
    3Coins
    Hello Vaue1, i m using the lasest version of the plugin. i try everyting i can do, but still like that, now just less "about the default installation position". i will let you know the ending when i reinstall the NL2 in the default installation position.
  12. donald
    Free Job People
    3Coins
    Thanks for remind me for this, i think this may the last or only reson ~ i will try to reinstall and repatch again~~~
  13. donald
    Free Job People
    3Coins
    @AceOfSpies @value1 bad news is, i reinstall NL2 in the default floder. the nightmare continues......sigh T_T
    153,836Coins
    +11,151 / 57 / -2
  15. donald
    Free Job People
    3Coins
    Hello noobeast. i fix the dpi issue befor. it is ok ~ but as you said about the language issue~ it may really the problme form! i just face this problme with Dashboard sofeware Z1DASH~~~ i will try it now~~~~thanks!
  16. value1
    14,239Coins
    I just can confirm that the plugin works with NLS V2.2.1.2 :)
  17. AceOfSpies
    19,614Coins
    @value1 - NLS2 version released 9th December = 2.2.1.3
  18. value1
    14,239Coins
    Funny, my PC updated today to 2.2.1.2 :)
  19. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    Same here.
  20. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Im guessing maybe Steam vs. Non-Steam?
