Showroom CXC inspired design!
  1. bsft
    Looks good man, the only thing id suggest is making a steel frame/supports under that motor plate. As it will flex like a muthaf...ker under motor power
    weld up something in the same size steel as you have now. Do not just the back, but under the entire area under those motors at the front and sides as well
  2. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Will do...
    151,638Coins
    +11,043 / 56 / -2
    In addition to @bsft's suggestion you could run a bar between the motors, which helps make them part of the structural design and adds a lot of rigidity.
  4. Nick Moxley
    17,056Coins
    Im assuming those lever's on the motor's are temporary ?
  5. josemanuelrm26
    josemanuelrm26 my 2dof
    valencia
    - 8Coins
    a great job I really like. I also have taken my simulator reference the same original but instead of moving the seat I mounted engines platafoma front so the entire move.
    it seems to me more real as the car engine is front and forces makes front. in my thinking. congratulations for your very professional work.
  6. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Thanks!
  7. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Yes! They are temp i just do not know if those motor are good for sim racing, if they work i i will change it for a better Bars.
  8. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Yes! The levers are temp.
  9. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    image.jpeg Hello everyone i have an update on the monitor stand. See pictures:
  10. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
  11. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
  12. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    size are your monitors? I have 27" and want to build a 8020 monitor arm.
  13. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    My monitors are 24" and old so i am planning on buying new monitors maybe 35" 144Hz.
    I am using 1-1/2" by 3" t-slotted alluminum with 1" locking pivot.
  14. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Whats the length though of each arm including the middle?
  15. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Hello everyone, I am creating a drawing for a Dashboard for the control panels with buttons etc, and I was wondering if any of you have a Fanatec Wheel base? I need the center dimensions of the Steering column? to allocate space in my design see picture for reference?
    in advance thanks!
  16. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I will check this afternoon and let you know?
    151,638Coins
    +11,043 / 56 / -2
    I would rather someone else also verify this, the 145mm is close but with the wheels shaft and my bad eyes could be out a little.
  18. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    The total length of the arms are 61 inches, left and right arms are 15 inches, Center is 27 3/4 inches, keep in mind that the left and right arms monitor bracket it extend to the center of the monitor, i also can adjust the location of the bracket.
    Best,
    Milton
  19. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Thanks this helps!
  20. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    I agree with @noorbeast I get the same 145mm x 70mm probably not mm perfect as my eyes are probably older and dimmer than his HeHe
