Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. uru
    uru New Member
    81Coins
    2DOF, SCN5
    I mean when, for example, you turn the wheel in a curve the seat hasn't movement. Are all the sensations that are not ok.
  2. uru
    uru New Member
    81Coins
    2DOF, SCN5
    I just received the communication from Lince that they're working to adjust the moviment. I'll see...
  3. Nick Moxley
    Im not 100% up on the development on DR, Who is Lince ? What are they working on and is there a forum discussion on this matter ? Honestly never once ventured to the CM forums so wouldn't know.
  4. puresound
    puresound New Member SimAxe Beta Tester Gold Contributor
    37Coins
    AC motor, 6DOF
    hi every one .
    i am playing Grid 2 and attaching my simdash from symproject (Pro-Gauges card) and having my 2DOF with simtools
    but when ever i start the game both GameEngine or simdash crashs.
    links .
    http://www.symprojects.com/shop/category/pro-gauge&controls=off/
    i tried every thing over here but i couldnt do what i am looking for.
    i used CodemastersProxyServer_v2.4.2a to help using multi API but no use
    any advice ?
  5. uru
    uru New Member
    81Coins
    2DOF, SCN5
  6. puresound
    37Coins
    AC motor, 6DOF
    hi every one again
    i managed to make codemaster proxy server work for simdash and simtools to give motion and dash reading
    but that work in dirt rally but only
    its not working in grid2 or any other codemaster games
    is there some thing i have to do with the plug in or it needs to be updates
  7. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
  8. puresound
    37Coins
    AC motor, 6DOF
    @tombo thank you so much for your help
    i find a way to make all codemaster games work with one plugin
    i choose dirt rally plug in because it support simdash and simtools
    by doing simple thing :)
    Example :GRID2
    copy the grid executable (grid2_avx.exe ) to your desktop
    then rename by (drt.exe)=DiRT Rally.
    return back the file to the folder and execute it
    all of CodemastersProxyServer_v2.4.2a + simdash + simtools will see the game as DiRT Rally
    all the best
    • Winner Winner x 3
  9. Nick Moxley
  10. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    Thanks Bob!
    It is very usable treatment!
    I had a same issue. My rig did not move with DR plugin.
    Changed values as you mentioned and it is works fine already!
    This helped me, thank you!
    Path is usually: C:\Users\<user>\Documents\My Games\DIRT Rally\hardwaresettings
    (It was not clear to me at first...)
    Have a nice day to all
  11. drazic
    drazic New Member SimAxe Beta Tester Gold Contributor
    - 135Coins
    No motion since Dirt 1.0. Will there be an update ?
  12. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    read above
  13. value1
    15,076Coins
    Or
    • Unpatch the game in GameManager
    • Delete the files in C:\Users\User\Documents\My Games\DiRT Rally\hardwaresettings.
    • Delete the file "hardware_settings_config.xml" in C:\Programs\Steam\SteamApps\common\DiRT Rally\system.
    • In Steam select the Dirt Rally properties Verify Integrity of Game Cache…
    • Run the game once.
    • After closing the game patch it in GameManager and enjoy!
    • Useful Useful x 2
  14. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    Thanks value 1. I follow your instruction but no motion., sigh sigh
    This is my hardware_settings_config.xml
    As you can read port is 20777 Is correct? In profile editor is indicated port used 4123 ??
    Can yuo please help me?
    <?xml version="1.0" encoding="UTF-8" ?>
    - <hardware_settings_config version="11" deviceId="0x6818">
    - <cpu>
    <threadStrategy workerMapFile="system/workerMap6Core.xml" forceFeedbackProcessor="4" dvdStorageProcessor="5" dataSetMonitorProcessor="1" renderProcessor="0" updateProcessor="2" fileStreamProcessor="3" />
    </cpu>
    - <audio_card>
    <dynamic_range value="high" />
    <eq value="flat" />
    <voice_chat enabled="true" />
    <push_to_talk enabled="true" />
    </audio_card>
    - <graphics_card rating="1" firstBoot="true">
    <directx forcedx10="false" />
    <eyefinity force="" osd="" />
    <stereo enabled="false" separation="0.015" convergence="0.5" />
    - <resolution width="1024" height="768" aspect="auto" fullscreen="false" vsync="0" multisampling="off">
    <refreshRate rate="60" />
    </resolution>
    <gamma level="0.8" />
    </graphics_card>
    <shadows enabled="true" size="768" maskQuality="0" particles="false" />
    <advanced_fog enabled="false" />
    <particles enabled="true" wind="true" dynamicRes="true" lowResScalar="4" nearFadeBias="0" />
    <weather quality="0" />
    <crowd enabled="true" detail="1" />
    <cloth enabled="true" tessellation="false" />
    <groundcover mode="atoc" clutter="false" />
    <objects lod="1.0" maxlod="0" stones="false" />
    <trees lod="0.75" maxlod="0" meshes="true" meshes_in_all_passes="false" />
    <vehicles characterQuality="2" lodQuality="1" />
    <track lod="0.6" />
    <envmap faces="0" size="128" drawallobjects="false" scaleminsize="2.0" mindistance="0.0" />
    <water update="false" detail="0" scale="8" drawallobjects="false" tessellation="false" />
    <mirrors enabled="true" width="192" height="64" car_maxlod="3" car_culldist="100.0" />
    <skidmarks enabled="false" />
    <dynamic_ambient_occ enabled="true" quality="1" />
    <dynamic_ambient_occ_soft enabled="false" />
    <night_lighting volumes="false" lights="100" shadows="false" onlyHeadlights="true" shadowSize="1024" />
    <textures resolution="1" />
    <shaders quality="0" low_quality="false" />
    <anisotropic min="1" max="1" />
    <physics environmentalDamage="true" vehicleDamage="true" />
    <input device_type="auto" />
    <screenshotMode enabled="false" />
    <aoit enabled="false" />
    <avsm enabled="false" />
    <mouse_support enabled="false" />
    <oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" verticalOrientation="0.66" orientationLock="false" />
    - <motion_platform>
    <dbox enabled="true" />
    <udp enabled="false" extradata="0" ip="127.0.0.1" port="20777" delay="1" />
    <fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
    <controls neutralTimeToShift="0.25" />
    </hardware_settings_config>
  15. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    N
    No you till had UDP endabled set to false, Did you read the thread?
    • Agree Agree x 3
  16. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    And extradata try set to "3" instead "0"
  17. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Take a look here:
    http://www.xsimulator.net/community/threads/codemasters-dirt-rally-plugin.6823/page-10#post-92997
  18. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    I apologize maybe I am a bit stupid and do not understand but I'm here 'just to learn
    I Unpatch the game in GameManager, I Delete the files in C:\Users\User\Documents\My Games\DiRT Rally\hardwaresettings,
    I Delete the file "hardware_settings_config.xml" in C:\Programs\Steam\SteamApps\common\DiRT Rally\system.
    In Steam I select the Dirt Rally properties Verify Integrity of Game Cache…
    I Run the game once.
    After closing the game I patch it in GameManager and modify the string in: C:\Users\gigi\Documents\My Games\DiRT Rally\hardwaresettings\hardware_settings_config.xml
    I did not modify anytyng in C:\Program Files (x86)\Steam\steamapps\common\DiRT Rally\system\hardware_settings_config.xml but only in C:\Users\gigi\Documents\My Games\DiRT Rally\hardwaresettings\hardware_settings_config.xml
    Now my hardware_settings_config.xml in C:\Users\gigi\Documents\My Games\DiRT Rally\hardwaresettings\hardware_settings_config.xml is follow:
    - <cpu>
    </cpu>
    - <audio_card>
    <eq value="flat" />
    </audio_card>
    - <resolution width="1280" height="720" aspect="auto" fullscreen="true" vsync="0" multisampling="off">
    </resolution>
    </graphics_card>
    <track lod="0.6" />
    - <motion_platform>
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" />
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="20777" delay="1" />
    </motion_platform>
    but whe I start a game a message advise methat Sim Tools Gamemanager stopwork for an error, and sim ....not work...
  19. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    I also tryed:
    <udp enabled="true" extradata="0" ip="127.0.0.1" port="20777" delay="1" />
    But Simtools game manager stop work
  20. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    in C:\Programs\Steam\SteamApps\common\DiRT Rally\system. the udp string is <udp enabled="false" extradata="0" ip="127.0.0.1" port="20777" delay="1" />
    I didn't change it after Verify Integrity of Game Cache…
