value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Hi !
    Thanks, but I got 6.2 finally so I was able to really start dev. I have a simple VB UDP receiver which works nicely. I need to integrate it in the XSim plugin architecture, but I'm not very succesfull for now.
    The UDP decoding goes well in the standalone version. I could feed easily a dash through serial with this code, without going through the XSim GameDash, but I'd like to go for the full picture directly. Ambitious, but otherwise I might stop in the middle.....
    Telemetry DATA received
    Game : 2 Session:1
    Pos : 2,559766 -29,60893 2,769726
    Accel: -1,000764 -0,03999925 -0,2557268
    Speed: 65,35105 RPM:8955 Max RPM:9100
    Gear: 4
    Game : 2 Session:1
    Pos : 2,544504 -29,2556 2,695577
    Accel: -1,409137 0,06986172 0,2390975
    Speed: 65,38105 RPM:8890 Max RPM:9100
    Gear: 0
    Game : 2 Session:1
    Gear: 0
    Game : 2 Session:1
    Pos : 2,559241 -28,74861 2,550955
    Accel: -1,376623 0,1264467 0,3375969
    Speed: 65,27573 RPM:8593 Max RPM:9100
    Gear: 5
    This was during a gear shift. I was excited when I got this result. There are so many data to use !
    I'm a low-level dev (more ASM/shell than object programming) so it will take me some time to get used to VB code used in the plugin framework.
  2. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    151,504Coins
    +11,041 / 56 / -2
    For VR fans there is an interesting comment on the latest patch note thread which includes an update to the Oculus 0.8 SDK.
    A bit further down in the patch note thread is the interesting bit, where the Project Cars team are already prepping for the public release of the Oculus SDK1, which for consumers is due when CV1 ships, but key developers already have it: http://forum.projectcarsgame.com/sh...elease-Notes&p=1215049&viewfull=1#post1215049
    I do hope they fix the VR shadow issue by then and optimise for the higher fps of the CV1.
  4. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    UDP telemetry has also some bugfixes :grin
    My UDP plugin, including gamedash is almost ready..... as the MaxRPM is available through telemetry, I have also added to CardashX the max RPM value to make it easier.
    Still need to test more deeply on PS4 and adjust a couple of things with @value1 and @yobuddy
    I'm still having issues with fuel level among others.... but I'm progressing quickly now.
    • Informative Informative x 3
  5. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    What are the benefits of this UDP version for Dashboard?
  6. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    UDP allows nice apps such as pCars Dash on android, vrHive on PC to work through network. No shared memory mess (I'm more a system/network engineer thn a high level developper) and ...... support on consoles such as PS4 and XBoxOne !!!! I work on a PC all day, so when I'm home I like to power-on my PS4 and simply play :p
    UDP is also something which looks to be more easy to implement for third-party apps, assuming the game developpers consider it.
  7. yobuddy
    50,757Coins
    @vthinsel, maybe consider calling this version of the plugin the "console" version or something similar.
    As the PC version also uses UDP I believe.
    Just so it's not confusing in the end.
  8. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    The current version uses shared memory, so this one is quite different. So calling it "Project Cars UDP" would make sense
    Cheers
  9. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Why does it say download no available? im not getting motion with 8.0 I also cannot run the plugin installer in admin mode, I get the circle with a cross through it. I have UDP set to 1 in game but dont see that other mm something in the options.
  10. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    I havent uploaded the UDP plugin yet. The current one uses shared memory.
  11. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Here is a video of the "in dev" plugin
    If you have any remarks/questions on the yaw/pitch/roll heave/sway/surge values I'm open ! especially I'm not sure I didn't invert pitch and roll. Could someone validate I'm not mistaken ?
    Check various moments of the video to get gamedash and tuning center in action
    Thanks for your feedbacks
  12. Nick Moxley
    17,056Coins
    Watching those Axis on the first part of the video, They dont look right at all. Surge for instance, Also pitch and heave....i dunno....just doesn't look right to me.
  13. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    I have changed some axis presets for a more "classical" 2DOF. Roughly same behavior, including surge which is generally "high". I also noticed my max/min weren't good; too low in fact.
  14. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    @value1 is something wrong with the file? It says I cant download it. I have over 4k coins so its not that.
  15. Historiker
    9,208Coins
    Download worked for me, try a different browser or perhaps reboot your PC? If that doesnt work let me know and I can email it to you.
  16. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
  17. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    but I can go to other plugins and download is fine. I was in chrome and just tried it in firefox, same thing.
  18. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    PCars offers 4 type of values which can be turned into forces. Here they are, in action:
    The values are in m/s (so divide by 9.6 to get G)
    Which would be good candidates for heave/sway/surge ?
  19. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    I think I found the good values to use using data dumped to a CSV file on a straight line with some steering applied one left, once right
    Plugin is nearly finished :)
  20. SilentChill
    20,586Coins
    Can I ask why you are making a new plugin as the plugin we have works perfectly for me ????
