Project 2Dof
Discussion in 'DIY Motion Simulator Projects' started by Bordiin, Sep 30, 2015.
  1. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Hi @Bordiin, any universal joint from a car drive shaft will do. As shown in your video, a CV joint will rotate
    And has to be braced to prevent rotation. A drive shaft UJ does not need bracing.
    Mike
  2. Bordiin
    Bordiin Active Member
    Brazil
    159Coins
    hello @AceOfSpies,
    i'm searching for universal joint, but i don't find yet.
    But thanks for your advice
  3. Nick Moxley
    Local Junk Yard is your friend. ;)
  4. Kass55
    Kass55 Member
    PC support
    315Coins
    Hi, I have just completed my 2Dof build using wiper motors and similar layout to you.
    Yes I used M8 rod ends (see pic) top and bottom
    screwed on to a M8 threaded bar - cut to length (mine are 400mm each) to give pivot movements top & bottom.
  5. Kass55
    Kass55 Member
    PC support
    315Coins
    I also think you need the top mounts on to the seat base raised higher.
    I ideal height of top mount is in line with your centre of gravity, which is the approximate height of your belly button when sitting on seat,
    this will give you a more even controlled roll effect (side to side) with lower power motors.
  6. le prefet
    le prefet New Member
    bourges
    480Coins
    si je resume pour des moteurs d'essuie glace (don
  7. le prefet
    bourges
    480Coins
    désolé pb de messagerie
    avec des MEG il faut les mettre à l'arriere du siege avec de longue biellette au niveau des épaules ?
    merci
    Moderator Edit: Le Prefet, by all means post in your own language but please also include an English translation so others can help you with your questions. Google Translate is a very easy, and quick, tool.
    English Translation:
    sorry bp messaging with MEC must put them to the back seat with the long rod at the shoulders? Thank you
  8. Icefox
    Icefox Member
    549Coins
    il y a plus de levier avec une prise au niveau des épaules les moteurs forcent moins
    Moderator Edit: Icefox, by all means post in your own language but please also include an English translation so others can help you with your questions. Google Translate is a very easy, and quick, tool.
  9. le prefet
    bourges
    480Coins
    merci, c'est donc la solution pour les MEG en 12V si on veut pas mettre une fortune dans des smoka ou autre en 24V
    merci
  10. shaman
    shaman 2dof sim
    Moscow
    - 964Coins
    good work :)
  11. le prefet
    bourges
    480Coins
    thank you, this is the solution for MEG 12V if we want to put a fortune in smoka or other 24V
    Thank you
  12. RENATO
    RENATO New Member
    - 98Coins
  13. sjmy
    sjmy i like a wind
    china
    194Coins
    2DOF, SCN5
    :cheers its so NB!
  14. jefesant
    jefesant Member
    Mechanic
    China
    16Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
  15. Demitsuri
    Demitsuri New Member
    Moscow Russia
    244Coins
    Hello guys! In very new in those community, so hope you can help me with my project.
    I cant find information, because it is motorcycle platform, not car.
    I need to know, which engine i must use with my sim. Im attaching the pictures, with project.
    Engine arms lenght is 30 cm.
    Also, i will be very thank you, if you can help me add traction loss DOF.
    Im attaching picture of my project.
    Already thank you.
  16. Bordiin
    Brazil
    159Coins
  17. Blame73
    Blame73 Well-Known Member
    8,304Coins
  18. noorbeast
    152,111Coins
    +11,066 / 56 / -2
    As @AceOfSpies suggested any universal joint from a car drive shaft from any wreaking yard would be a far more robust option.
  19. Bordiin
    Brazil
    159Coins
  20. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    Or you can build your own :
