3 DOF build (scn5 actuators) new project
Discussion in 'DIY Motion Simulator Projects' started by haroldjames, Dec 12, 2015.
  1. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    they are pretty hard. we use them on equipment to carry a fairly heavy load on a turntable for wrapping skids. The insert bearing is a 6201-RS
  2. Nick Moxley
    Any wobble on the front end ? like push down on either front corner and see how much deflection the frames have against each other.
  3. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    The top frame sits solid on the lower frame. It move very smooth side to side. All wheels have bearings and the front pivot point is a timken cup and bearing. Most of the wieght will be centerd on the seat when you are driving making it even more stable.
  4. Nick Moxley
    Thats not the question i asked, But ok.
  5. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    If you push down it will tip. The solution to that if it a problem is to secure the front pivot piont so thete is no side play in the shaft that goes through the bearing. Is this what you are trying to make aware of, top being tippy? thx nick:)
  6. Nick Moxley
    Correct, without supports like caster, i fear it will have a tendency to "wobble" if you press on either front corner. The problem isn't in motion per say but with your Steering wheel and fighting the wheel's feedback, the top frame will want to roll side to side adding pressure to the Front bearing and if there isn't support on either front corner is can have a "tippy/wobble" effect. I guess if you could somehow "load" that timken cup bearing exactly as you would on an Axle you might be able to prevent the problem, but In all honesty i think it'll still wobble a bit being as heavy and large as our rigs tend to be.
    This was my quick 20min fix for mine, Granted i dont have a Large Axle bearing as your using. but rather a 12" round lazy susan which has far more "surface area" to prevent the wobble, yet it still did.
    Front outside corner's
  7. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Thank you for the info. I will certainly take it under advisement. Your fix may work for me if its needed to stabilize the motion. thx Nick!
  8. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Well today I got the seat frame welded together and the u-joint mounted in place on the frame. I took a couple of pics of it.
  9. Nick Moxley
    Wow you must have some Serious Man Cave space to play with, That base is a Monster.
  10. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Yea, she is going to be faily big. lol
  11. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Got a little more work done today. Fabricated motor mounts for the seat.
  12. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I have not purchased the scn6 yet for the traction loss. Could someone guide me on the one to buy. I did read that the scn6-020 is ok, but what stroke should it be. 100mm or 150mm. thanks
  13. noorbeast
    153,053Coins
    +11,117 / 56 / -2
  14. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    thank you for the information noorbeast. i will check out all the options you listed.
  15. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Update: continuing to weld the frame pieces.
  16. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Today I got my grandson to help with the frame. We decided to cut the frame in half and use joiners to put it back together. This will allow us to move the rig by disassembling it.
  17. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    grandson is helping to get the rig done quicker but forgot to wear safety glasses:nerd
  18. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    No, If you look real close you will see he as on a set of plastic goggles. they are hard to see unless you zoom in. lol, you were not the first person to say that. :)
  19. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I just looked at the posting myself and you cant see them there, but I swear he does have them on.
  20. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Side frame now complete and rear mount with anti-vibration isolators.
