RaceRoom Racing [FOV] Best Inmersion in our Cockpit
Discussion in 'Virtual Racing League' started by carloscasas, Oct 30, 2014.
  1. carloscasas
    carloscasas Member
    322Coins
    Translation by Gonzalo Camara http://boxthislap.org/
    Carlos Casas (Total Spanish Simulator) wrote a useful guide a few months ago about how to get full immersion in our sim. Here it is a briefly translation.
    Setting hardware the right way
    LINK PDF
    http://www.totalspanishsimulator.com/manuales/varios/consejos inmersion.pdf
    1. Distance to the main screen
    “The closer, the better”
    As you probably imagine, the closer you are, the better realism and immersion you get.
    With this subject in mind there are different variables, as the screen size.
    Below 27 inches ideal distance is about 60 cm, always calculating from the driver eyes to the main screen.
    Bigger screens need to increase this distance up to 10 cm, no more. Over 70 cm is not recommend because lack of coherence between “real” and “virtual” objects.
    It takes time to accommodate to these kind of short distances.
    Wrong
    RIGHT
    2. Height of the sight
    Right focus of our sight has to be in straight line to the “road”. You achieve this when your eyes are at the 60% of the height of the screen. There is no need to change the focus or other inconveniences physical issues.
    Wrong
    Right
    3. Wheel position
    The ideal is to overshape wheel virtual silhouette with the physical, always leaving a short distance between 3 and 6 cm. Bear in mind you have to accomplish the previous distance and height guidelines before and feel comfortable in your driving position.
    Wrong
    Right
    4. Seat
    Check in your sim which options you have to calculate the height and the distance of the seat and the wheel. Mostly you got an approach with the previous steps.
    Wrong
    Right
    5. Field of view
    Disable virtual representation of the driver hands and wheel.
    It is really important to understand what is happening before our eyes. Lastly every sim has its own FOV calculator that helps to set depending on the height and distance measures. When the FOV is wrong there is an tunnel effect that distorts the speed feeling and feedback. When you try to get a balance with one screen it is important not forget the vehicle sides.
    Wrong
    Right
    6-Covering
    Even with only one screen is advisable to get a cover. Its function is avoid every kind of distractions for our sight. Speed feeling is also better.
    Wrong
    Right
    7- Triple screens
    Frames are important value to consider when you are setting a triple screen configuration. Try to get something with less than 10mm. To reduce this black strip you can overshape frames of the monitors.
    To calculate angles of the triple screen there are different tools which with a few value inputs can show your ideal FOV, angle and distance to get the ideal configuration.
    Lateral screens Angle
    Link Calculator
    http://www.totalspanishsimulator.com/manuales/varios/CALCULADORA FOV 3 PANT.xls
    Wrong
    Wrong
    Right
    8-SUPER FOV
    Big screens with projectors which wheel is very close to the main screen.
    A big single screen has the problem due to the distance of our sight to distant points of the sides.
    Three panels or curved panels don’t seem to have same problem if you use a software to correct the FOV.
    3 panels
    Curve Panels
    http://www.youtube.com/watch?v=25KB1OJoYeA[/youtube]
    9-Virtual reality
    Seems the next big thing. It promises a total immersion getting you into the game. Speed feeling and head tracking incorporated. In the con side, still in development, lost the physical limbs and fingers, not a human real FOV yet, not a big resolution yet, feeling sickness, etc.
    We will hope the next CV1 will solve some of these issues.
    • Like Like x 7
    • Informative Informative x 6
  2. RacingMat
    21,059Coins
  3. carloscasas
    carloscasas Member
    322Coins
    Your welcome!!!!
    Yes, i know these manual since 4 years ago.
  4. RacingMat
    21,059Coins
    Good idea: building covers around the triple screens...
    maybe my next work!
    (the xls url is not working properly... the name is ok but not the html behind)
  5. carloscasas
    carloscasas Member
    322Coins
  6. RacingMat
    21,059Coins
    perfect!
  7. bsft
    good information there, its informative.
    However, people will use what ever is best for them within reason and room.
    Oh and dont show this on ISRTV forums, they will go nuts!
    Dave.
  8. carloscasas
    carloscasas Member
    322Coins
    LOL
  9. ferslash
    ferslash Active Member
    4,798Coins
    woow, grate info i had not idea of any of this stuff
  10. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
    thanks! never thought of the covers on top and sides I`m gonna try this!
  11. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    just to bring this topic up ... all new sim builders have a look here.
    You can improve your immersion factor a lot by following this simple advice.
  12. highground
    highground New Member
    Brisbane, Australia
    272Coins
    Thanks for the great guide, perfect for someone like me that has no idea!
  13. carloscasas
    carloscasas Member
    322Coins
    News.
    Finally i sold my 3 27" screens and i bought the Oculus DK2. More inmersion although the resolution is worse.
    I think the VR headsets will be the future.
  14. LibranRabbit
    LibranRabbit New Member
    19Coins
    Thanks for the info! I'll be looking closely at my distances, angles and somehow adding a cover. Info like this, is what "drives" us! Lol.
  15. Slider
    Slider Active Member
    Irrigation
    Brisbane
    1,130Coins
    2DOF, JRK
    Thanks, this has some very useful info.
  16. Gadget999
    12,041Coins
    Which is better
    3 screens or a projector onto a wall ?
  17. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    see this post now. ok... for many years, i use 6 monitors ( 3 for fov and more 3 for maps, telemetry, etc ) on 2005, i try 3 projectors, but lumens are weak, and resolution at this time, not so much. Well... on 2015, try VIV VR and i simple SELL all other monitors ! rs... VR definitly have an HUGE imersive and greatifull experience.
  18. djboss001
    djboss001 Member
    Test engineer
    - 34Coins
    An oculus rift ;)
    Personally I prefer 3 screens, the peripheral field of vision is better than with a projector.
  19. paulopsx2
    brasil
    647Coins
    6 monitors:
  20. djboss001
    djboss001 Member
    Test engineer
    - 34Coins
    Excellent immersion but WAF = 0 :confused:
