Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    hallo.
    Problem solved
    I delete old plugin and installed new version. my sim move again and dashmeter work
    thanks
  2. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    is this working good?? I missed to download this during my download period...uhm..
  3. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    no motion... any idea?? uhm...
    simtools seems to get the telemetry data from the game but no motion... refer to the attached screenshot.
    please have a look.. your help would be appreciated..
    <?xml version="1.0" encoding="UTF-8" ?>
    <hardware_settings_config version="11" deviceId="0x13D8">
    <cpu>
    <threadStrategy workerMapFile="system/workerMap4Core.xml" forceFeedbackProcessor="3" dvdStorageProcessor="3" dataSetMonitorProcessor="1" renderProcessor="0" updateProcessor="2" fileStreamProcessor="3" />
    </cpu>
    <audio_card>
    <dynamic_range value="high" />
    <eq value="flat" />
    <voice_chat enabled="true" />
    <push_to_talk enabled="true" />
    </audio_card>
    <graphics_card rating="4" firstBoot="true">
    <directx forcedx10="false" />
    <eyefinity force="" osd="" />
    <stereo enabled="false" separation="0.015" convergence="0.5" />
    <resolution width="1024" height="768" aspect="auto" fullscreen="false" vsync="0" multisampling="4xmsaa">
    <refreshRate rate="69" />
    </resolution>
    <gamma level="0.8" />
    </graphics_card>
    <shadows enabled="true" size="3072" maskQuality="2" particles="true" />
    <advanced_fog enabled="true" />
    <particles enabled="true" wind="true" dynamicRes="false" lowResScalar="2" nearFadeBias="0" />
    <weather quality="1" />
    <crowd enabled="true" detail="4" />
    <cloth enabled="true" tessellation="true" />
    <groundcover mode="ultra" clutter="true" />
    <objects lod="1.02" maxlod="0" stones="true" />
    <trees lod="1.2" maxlod="0" meshes="true" meshes_in_all_passes="false" />
    <vehicles characterQuality="4" lodQuality="3" />
    <track lod="1.0" />
    <envmap faces="6" size="1024" drawallobjects="true" scaleminsize="0.75" mindistance="150.0" />
    <water update="true" detail="3" scale="2" drawallobjects="true" tessellation="true" />
    <mirrors enabled="true" width="768" height="256" car_maxlod="1" car_culldist="300.0" />
    <skidmarks enabled="true" />
    <dynamic_ambient_occ enabled="true" quality="4" />
    <dynamic_ambient_occ_soft enabled="true" />
    <night_lighting volumes="true" lights="0" shadows="true" onlyHeadlights="false" shadowSize="2048" />
    <textures resolution="3" />
    <shaders quality="2" low_quality="false" />
    <anisotropic min="4" max="16" />
    <physics environmentalDamage="true" vehicleDamage="true" />
    <input device_type="auto" />
    <screenshotMode enabled="false" />
    <aoit enabled="false" />
    <avsm enabled="true" />
    <mouse_support enabled="false" />
    <oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" verticalOrientation="0.66" orientationLock="false" />
    <motion_platform>
    <dbox enabled="false" />
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" />
    <fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
    <controls neutralTimeToShift="0.25" />
    </hardware_settings_config>
  4. josemanuelrm26
    josemanuelrm26 my 2dof
    valencia
    - 8Coins
    me too extradata one I work with what I had in extradata 3 with the Arduino and motomonster
  5. Shige Tanaka
    Shige Tanaka FREX Actuator Supplier http://www.frex.com/gp/ SimAxe Beta Tester Gold Contributor
    FREX
    Osaka Japan
    - 274Coins
    2DOF, 6DOF
    It seems pick up wrong data. I do not know various version exists? Depend on OS Language or STEAM version. It happen on other Codemasters game Dirt3 too.
  6. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
  7. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    @Shige Tanaka @prodigy
    Back when I found this bug I noticed that it only happens while you are in windowed mode. It also does the same thing in Sim Commander so it is a problem with the telemetry coming from the game rather than a Sim Tools bug.
    As far as I am aware the bug still exists, I am currently building my new PC so I don't have my motion simulator set up so I can't test it again.
    Try it in fullscreen and it should work fine. I have some videos of the problem in the link that @prodigy posted
  8. Shige Tanaka
    FREX
    Osaka Japan
    - 274Coins
    2DOF, 6DOF
    No success with full screen too.Change a little when I set the delay="1" to 2 to 20 values. I aware this Dirt Rally supports Oculus Rift natively WOW, need a motion seat to avoid VR sickness.
  9. Avenga76
    Network Engineer
    3,261Coins
    Yeah, the Oculus Rift is really good for Dirt Rally, I just which they had the drivers arms because it looks a bit weird as just a floating head.
    Once I finish building my new PC I will give it another test and see if I can get it running smoothly.
  10. SilentChill
    20,590Coins
    I had to manually patch the game it works fine using extra 1.
    You do have arms you need to turn them on in preferences ;)
  11. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    I don't actually recall doing anything to fix this, it kind of just went away after the first few updates (to the game itself..)
  12. SeatTime
    Just getting back into this with my new rig, 'Direct' Rift support and menus are a welcome relief :thumbs.
  13. Avenga76
    Network Engineer
    3,261Coins
    Is anyone able to get good performance with Dirt Rally on the Rift? I have a pretty quick PC, i7 6700K @ 4.7GHz, GTX 980 and 16GB DDR 4 RAM, but I struggle to get 75FPS. Other games are sweet and I just rebuilt my PC and it is still slow in Dirt Rally. I find the shadows really kill the FPS. It runs okay on low but I feel I should be able to crank it up higher since I can run games like iRacing at 150-200FPS on max settings with 8X AA
    151,991Coins
    +11,061 / 56 / -2
    I don't have Dirt Rally, I would grab it if it has the Hummer as in Dirt 2 and 3 but have not been able to confirm if it does or not. Hence my following Rift related comments are general rather than specific to Dirt Rally.
    Unfortunately shaders of various types are one of the performance killers if not done specifically for VR. Sometimes you just have to live with it, though in some cases you can mess with the graphics pipeline with Nividia settings and things like SweetFX, though the latter often has support broken by updates. The results vary from game to game and what computer hardware is used. Your rig is fine for VR, it is the game that is the issue, so try messing with Nividia settings first and see if that helps.
  15. prodigy
    Croatia
    6,698Coins
    There is also some kind of Blending option, don't remember now whats called, but I've found it's taking good amount of FPS.
  16. MWB
    MWB Drive it like you stole it!!
    Commissioning Engineer
    U.K.
    424Coins
    2DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    Thanks for the plugin
  17. SilentChill
    20,590Coins
    Best advice I can give is to run it at 2560x1440 at 4xMSAA. Make sure you are in FullScreen always !!!
    Turn Ground Cover - Off
    Turn Shadows - Ultra Low
    Turn Shader Detail - Ultra Low.
    I have everything else set from Ultra to Medium I get a steady 75fps on my GTX970 no judder at all.
    With your setup maybe you can increase things I would think, but I would just try those and see what you get and take it from there, but ground cover and the shader kills mine its judder and ghosting city.
    Hope that helps a little.
    • Useful Useful x 2
  18. MWB
    U.K.
    424Coins
    I'm also struggling to get the game to run in full screen, stuck in windowed mode, any one got a fix?
  19. SilentChill
    20,590Coins
    ALT+ENTER = FULL SCREEN
    or you can go into the menu as above ^^^^^^^^ in the screenshot and select it.
    DO NOT CHANGE DISPLAY SETTINGS ONCE ON A STAGE DRIVING, THE GAME WILL CRASH WHEN USING THE RIFT !!
  20. MWB
    U.K.
    424Coins
    Tried that, didn't work! :(
