Nouveau utilisateur avec un Prosimu T1000 2 dof
Discussion in 'Commercial Simulators and Peripherie' started by Foehn, Nov 30, 2015.
  1. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
  2. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    and this one
  3. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hi Foehn and Hi dJuL :)
    by 15 January I will have a t1000 3DOF too!
    I am very happy to share together with you virtual driving sensations and simtools settings for various driving games.
  4. Doctor Kruntz
    400Coins
    3DOF, SCN6
    I am also very interested about Basspump adding to your dynamic system.
    You tell me what type of Basspump you purchased, which amplifier and what software you used to configure all?
  5. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    @noorbeast, Regarding the percentage allocation per axis, it's for jrk or also for the SNC ? Thanks
    151,668Coins
    +11,045 / 56 / -2
    The total axis percentage total should be independent of any particular board or actuator, as it is really about what SimTools can do with the allocation. Some including myself go a little over 100% in some circumstances, but generally the 100% total really should be the ideal target.
  7. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    @Doctor Kruntz I prepare for you all information about the basspump
  8. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Maybe you're right, in theory...
    Personally I already try lower values and I don't like.
    I've just tried again to divide by 2 my values to reach a 130% total, and I don't like the result.
    It's too smooth...
    There is a big difference.
    Time reaction of SNC are really quick, maybe it's why it's possible to have big %
    Also I think it's pretty rare (except in a big crash of course) to have all forces at the same time, so the total % in real gaming is not all the axis added.
    My goal is to use the T1000 at 100% for feeling, the actuators amplitude is not very big.
    If I lower the axis values, not all the amplitude of the front actuators are used, even in a big turn or a big braking...
    Foehn have you tried both ? what's your opinion ?
  9. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Many many thx, I wait for news about :thumbs
  10. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    if i understood you right i will try to explain in my words why we always have to use more than 100%.
    A car tyre has a certain potential (grip aka gforce) to either brake(accelerate) or turn.
    When a tyre performs at 100% braking potential then the tyre cant give the driver 100% of its turning potential.
    But it can still turn.(when the wheels are locked the braking potential is lower than maximum).
    i hope this explains it better than me
    151,668Coins
    +11,045 / 56 / -2
    The linear speed of SCNs are not as fast as high powered DC powered rigs.
    In many respects Axis allocation % is a bit like clipping in FFB settings, too much and you lose detail.
    Setting up a good motion profile is not just about the axis allocation, how the sim responds in terms of speed and responses relates to how the Tuning Center is used.
    For a given Axis % raising the Tuning Center value will soften the motion over a greater axis movement, lowering the value will do the reverse. If you are testing by winding up Axis % without modifying Tuning Center values then you re saturating rather than tuning the motion.
  12. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Yep I understand that.
    I will try again to go back to 130% and change values in tunning center to see if I manage to have, at least, the same feeling.
  13. noorbeast
    151,668Coins
    +11,045 / 56 / -2
  14. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Hello, Regarding the Basspump,
    BassPump
    Crossover
    Ampli
    I re-used the amplificator come from a little sub-woofer
    I use them in Serial, one under my seat (directly fixed on it) and the second behind the pedals (mounted on the home made plate and fixed on the thrustmaster pedal)
  15. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Used to filter the frequence (to have only the low frequences)
  16. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    2 Models (mount in serial)
    151,668Coins
    +11,045 / 56 / -2
    Do you have a link where you purchased this from?
  18. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    yes, you have two links (basspump & crossover) in my first topic
    do you see them ? (amazon)
  19. Doctor Kruntz
    400Coins
    3DOF, SCN6
    151,668Coins
    +11,045 / 56 / -2
    Sorry I use an ad blocker so no I did not see them, my apologies.
