Nouveau utilisateur avec un Prosimu T1000 2 dof
Discussion in 'Commercial Simulators and Peripherie' started by Foehn, Nov 30, 2015.
  1. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
    no problem, is it ok now ?
    151,467Coins
    +11,041 / 56 / -2
    I can see them if I turn the ad blocker off.
  3. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    @Doctor Kruntz r
    Actually, i use the basspump without software. They are connected on my principal sound card with a double jack 3.5mm connector (like the picture)
    is it understandable or do you want more informations ?
    For the ampli, you can take a 100w standalone or if you have a older hifi amplificator
  4. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Thanks again Foehn, it's all pretty clear although I would like to know precisely the sequence and the order of connections, maybe with a designed scheme :thumbs
    Meanwhile, I'm looking about a 100w power supply...
  5. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    My general settings and for AC (I continu to set them)
    I start to find a good sensation.
    I test with a track and car who I know well to compare the reality and the virtual
  6. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
  7. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
  8. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
  9. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
  10. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    151,467Coins
    +11,041 / 56 / -2
    That is a 220% Axis Allocation. You really need to refine your Tuning Center values.
  12. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Ok, noorbeast, I did not understood completely the total of 100%
    I will try this evening
  13. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    the scheme of my Basspmup installation (mono for me)
    let me know if it's clear ?
    • Useful Useful x 4
  14. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    I'm trying to do a new AC profile in tuning center with a total per axis lower than 120%
    I'm now at the first stage: surge force only, 25% in GE
    My problem is I have to set a value near 1 / -1 in tunning center to have a good feelling, and I don't manage to enter a "dot" to obtain a float value (there is too much differences between 1 and 2).
    I tried to set local OS and KBD to English/US but it doesn't fix anything... Each time I press the dot key it clears the value or sets it to zero... And unfortunately copy/paste doesn't work.
    Does anyone have an idea ?
    151,467Coins
    +11,041 / 56 / -2
    Did you change language settings like this and then try rebooting: http://www.xsimulator.net/community/faq/udp-games-produce-no-output-data.181/
  16. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Ok I've just found a solution.
    I opened a profile with dots in tuning center (like LFS)
    The trick is to copy/past the dot with the mouse right click (context menu).
    And It works great, now it's possible to set a float value even with local input set to FR.
    Hope it can help.
  17. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
  18. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Good news,
    151,467Coins
    +11,041 / 56 / -2
    Keep in mind that in some games forces like heave can have a value less than 1, like 0.9 all the way down to the minimum, which is 0.001
  20. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Many thanks for the perfect bassPump scheme Fohen... ;):thumbs
