Showroom DX - Compact Simulator
Discussion in 'DIY Motion Simulator Projects' started by noorbeast, Sep 29, 2014.
  1. ALMO
    ALMO New Member
    Australia
    325Coins
    Agreed Archie. This type of rhetoric has no need within this community.
    The DX racer is a good build for people seeking a cost+space effective motion solution.
  2. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    There's enough grief in the world. We don't need it on our, otherwise friendly, forum. Time to take a breath, and evaluate what is being gained by such discourse. Constructive criticism isn't an attack by anybody's standard. Anyone who has a problem with constructive criticism, possibly shouldn't be posting on a public forum.
  3. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Awesome Genius Work ...
    LLLLLLLLLLoove it :cheers ...
    151,991Coins
    +11,061 / 56 / -2
    The parts just turned up this morning to build my portable VR computer, but after being up all night with the Rift Pre-order I will leave putting it together until after I have had a good nights sleep.
    I also have other bits that are due any day now so I can build a portable haptic chair. That project will not have motion but the haptic setup may be of interest to others.
    • Like Like x 5
  5. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    System builder porn. Nice!
  6. 1oldbiker
    1oldbiker Member
    281Coins
    @Noor Are you going to have shakers mounted at various point on the seat? I think that would be cool. I've driven race cars and race boats and part of the thrill is all the thumps and bangs. Can Simtools strip the vibration data out?
    151,991Coins
    +11,061 / 56 / -2
    I have a a large Buttkicker mounted under the seat of my sim, have played around with creating a haptic harness and have set my rig up to add more transducers in the future.
    I am about to start building a portable 9 transducer haptic chair without motion, to experiment a bit more with haptics.
    At this stage SimTools does not support transducer control but it is a planned addition for the next version.
  8. 1oldbiker
    1oldbiker Member
    281Coins
    That will be an awesome addition.
    151,991Coins
    +11,061 / 56 / -2
    That is the sort of question you should ask on your own build thread. you can start one here:
    http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    I don't know of a Germam supplier.
    Your could import from Motion Dynamics in Australia, but I suspect shipping may be expensive: https://www.motiondynamics.com.au/industrial/
    This Canadian seller has similar motors and ships world wide: http://www.ebay.com/itm/GEAR-MOTOR-...483?pt=LH_DefaultDomain_0&hash=item51bed470a3
    As theses motors are hard to get or expensive in some places a possible alternative is modifying electric jack mototors: http://www.xsimulator.net/community/faq/modify-electric-jack-motors-for-sim-use.212/
    Or common winch motors, though these can be a bit noisy: http://www.xsimulator.net/community/faq/dc-winch-motors-for-motion-simulators.151/
  10. Azeal
    Azeal New Member
    Kuli Batak
    Singapore
    317Coins
    Woah; Ive finally finished reading this lengthy post. Took almost my entire night shift. Very in depth. I got two question though. Can this build use wiper motors instead? with regards to gear boxes(front two) must i use a left & right or can i get away with using just a left or right gear boxes. I doubt i can find Dc motor /gear boxes easily in my country. Amazing work Noorbeast!! :thumbs
    151,991Coins
    +11,061 / 56 / -2
    Unfortunately not @Azeal, a compact design like mine needs a fair bit of torque to drive it and wiper motors are not really suitable.
    I am changing the heave motor to 50:1 next week and really with the spring assist that would be suitable for all motors. You do need gearboxes that can't be back driven, otherwise the heave assist spring creates problems when nobody is on the sim but there is motion data, as a 25:1 is not strong enough to compensate for a spring that can balance your weight.
    151,991Coins
    +11,061 / 56 / -2
    This is the new compact VR computer I just put together, interestingly the brilliant Corsair case would neatly fit HP server PSUs if anyone wanted to build a portable PSU, control board and perhaps sound system out of one.
    Corsair Graphite 380T Mini ITX Black Gaming Case
    Gigabyte GA-Z170N-Gaming 5 Motherboard
    Intel Core i5 6600K
    Corsair Vengeance LPX CMK16GX4M2B3200C16 16GB (2x8GB) DDR4 Black
    Samsung 850 EVO Series 250GB 2.5in SSD
    HGST Travelstar 7K1000 1TB
    Corsair Hydro Series H100i GTX 240mm Liquid CPU Cooler
    EVGA GeForce GTX 970 FTW+ ACX 2.0+ 4GB
    Cougar RS 750W PSU (a modular PSU would be better but I already had this lying around)
    I deliberately chose the 2.5in 1gb 7500 rpm HGST drive for storage so I could remove the double bay 3.5 housing to give more room for cable management. If I ever feel the need for more space with cheap drives I can put the 3.5 housing back in, but as this is meant to be a portable VR rig for a 9 transducer chair I plan to build I won't be adding more to it than I actually need.
    20160108_123827.jpg 20160107_161901.jpg 20160107_162147.jpg 20160107_164054.jpg 20160108_131059.jpg 20160114_151953.jpg 20160114_152039.jpg 20160114_152146.jpg 20160114_152210.jpg
    • Like Like x 7
  13. Azeal
    Azeal New Member
    Kuli Batak
    Singapore
    317Coins
    @noorbeast Thanks for the reply. Well that means i need to go look around for motors at Sim Lim tower instead of a scrap yard during my off day. Wonderful rig you have there. Was wondering whether the Dell Alienware alpha or Zotac mini PC is powerful enough to run your game, simtools & the OC rift. A compact mini itx PC would look great on your compact sim
    151,991Coins
    +11,061 / 56 / -2
    While a mini PC supporting x86 could run SimTools and games not needing high end graphics, they are not suitable for VR which needs high end specs like the compact PC I just built.
  15. JlMMY
    JlMMY New Member
    sydney
    205Coins
    GJ Noorbeast, You tha KING
  16. skano ca
    skano ca tH3 bR1igHt3st star 1n the c0nst3llat10n HydRa
    engineer
    Malaysia
    102Coins
    Nice work. I like your compact sim
  17. eightbit
    eightbit Active Member Gold Contributor
    Fish Farmer
    Trentham Cliffs
    183Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    Noorbeast well done mate! Really is a nice bit of compact kit. Looking forward to seeing your future additions. All the best!
  18. noorbeast
    151,991Coins
    +11,061 / 56 / -2
    Much appreciated guys.
    I have since fitted the 50:1 gearbox for heave. While I had it in bits I swapped in the brand new boxed HP server PSUs that I got really cheap some time ago.
    At some stage I will make a new and longer aluminium seat base plate, just so I can squeeze a little more leverage on the heave axis, but it is not urgent just a longer term upgrade. Heave is great with most things but really shines when you have rally style jumps in games like Dirt 3 or tracks like Nordschleife.
    My next project will be messing more with a haptic chair rather than the motion sim.
  19. Juandi
    Juandi Member
    Engineer
    Mexico
    202Coins
    2DOF, 3DOF, DC motor, Arduino, JRK, Motion platform
    Great build!
  20. Dmraf
    Dmraf New Member
    Ufa, Republic Of Bashkortostan, Russia
    174Coins
    Very nice, compact and high quality! Works of art!:thumbs
