Greg's journey into the world of 2DOF simulators
Discussion in 'DIY Motion Simulator Projects' started by Greg83, Feb 17, 2015.
  1. Greg83
    Greg83 Active Member
    IT Specialist
    Budapest, Hungary
    328Coins
    Had an idea to try out SMC3 v0.6.zip or SMC3 v0.7.zip but upon compileing I get this:
    So can't try this either...
    I think this project might be doomed...
    Or should I just try to re organize my stuff according to racingmats draving?
  2. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    don't know if this is the problem but my knowledge for arduino is limited. why do you have two sketches opened in the arduino program open only the SMC3.ino
  3. Blame73
    Blame73 Well-Known Member
    8,306Coins
    just watched your video, the pot seems to move a lot.
    it could lead to a faulty precision, maybe rebounds
  4. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    @insanegr : that was the default sketch, had to reinstall my Arduino program and that sorted it. Uploaded the SMC3 v 0.6 and made a small test video:
    It seems the sim goes to middle only if there is 20% of positive input on Axis 1.
    But this whole movement seems too odd to me... Should it move like this with output testing?o_O
    @Pit , @RufusDufus , @noorbeast : any idea's?
    What I do not understand is why is Game Manager working like so if the SMC3 Utils is running like charm.
    Fundimentally the two control the rig diffrently?!
    Arduino Settings in device manager: Arduino settings.jpg
    @Blame73 : But the pot is moving as the motor changes position! And in SMC3 Utils it is fine nice and smooth! Shouldn't it be rugged in there too?
  5. Pit
    30,502Coins
    Please use Arduino software 1.6.5 or earlier
    Please upload a video of SMC 1.01, the buttons at the right side allows you to adjust the motors on "zero" middle position (middle position of the potentiometers). If SMC3 works fine (please check out the motion script) SimTools should work as well.
  6. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,364Coins
    @Greg83, here are my observations and assumptions:
    1. You post a screenshot of the device manager com port settings... This has no relevance for either SMC3Utils or Simtools, they automatically setup the com ports based on the in program settings so adjusting anything in device manager is a waste of time.
    2. You say everything is working well and tracking as required using Windows SMC3Utils... This means your hardware must be correctly assembled and wired and mechanically ok, with serial coms working to the arduino.
    3. This leads us to assume it is simply incorrect settings in simtools so focus there.
    4. As mentioned in an earlier post don't worry about start and end codes in the simtools interface settings (or if you do note that the center position is 512 not 128)
    5. I note in some of your earlier posts you had made changes in the simtools profile settings of the game manager... I would suggest keeping these in the default center position until you have the axis setups working properly. (*** my guess is this is your main problem ***) don't forget to check all game and default profiles.
    6. Also you show the settings for rFactor and Assetto corsa but the video is demonstrating manual output testing... you need to change/ensure the "default" axis assignments are correct for manual output testing.
  7. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    one other thing, if you can control manually motion in SMC3 utils and have configured everything in simtools right and still having problems check your region settings in windows control panel
  8. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    @Pit : Where is the motion script exactly? Downloaded an earlier verison, uploaded SMC to Ardiono using MODE1.
    @RufusDufus , @insanegr :
    Made two video's after I have decided to uninstall Simtools from my PC completely. Reinstalled it, set it up using the quick guide and tested it with SMC Utils 1.01 with sine and motion:
    Smooth as silk...
    And then with Simtools:
    I highly doubt that moving the slider to the positive end I should get movement both ways....
    Honestly wtf can I have messed up???
    I did not setup anything other that the ones advised by the manual!
  9. Pit
    30,502Coins
    Try to install SimTools again - download a fresh version and install it over the old version, do not delete your old settings.
  10. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    what are your region settings?
  11. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    Hey! Sorry left that out...:
    Windows language is English, but the regional settings are Hungarien.
    Does Simtools store any data anywhere else than the program folder?
  12. RufusDufus
    Adelaide Australia
    16,364Coins
    In early versions of simtools... If your region number settings used a comma for the decimal place (as yours appears to) you would experience problems with simtools.
    I thought the current release of simtools had fixed the issue but perhaps not.
    I would definitely change your settings to use a full stop (.) for the decimal and see if it fixes your problem.
    [EDIT: It may also be the digit grouping symbol... Best to use EN settings to see if it solves the problem and then work back from there to see which setting is causing the issue.]
  13. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    Thanks for the tip, first thing will be to try it out when I get home from work!
    I had one more idea yesterday with a friend, but don't know if its usefull.
    The idea is to factory reset the Uno and then program it from the beggining. Maybe the uploading of multiple sketches messed something up?!
    But then again if it would have messed something up then the SMC Utils would not work properly either right?!
  14. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    @Greg83 do what rufusdufus said and 99.9% (with a dot not comma:grin) you will run with no problems
    EDIT: something like this
  15. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    GUYS,
    (@RufusDufus , @insanegr , @Pit , @noorbeast , @bruce stephen )
    That was it... Had to change the whole regional settings to the US and bamm, no more tilting to the left! Axis working fine. :grin:thumbs
    Now it is off to tune the whole thing.
    Braking and gear changing is okay, but the Sway motion and Acceleration is still not really good! But it will be better.
    My current settings:
    This is version 6 I think.
    Sway was good in one setting where I had this exact same setting but the direction ticked in both sway boxes. But then Surge moved from left to right so that went to the trash bin :)
    THANK YOU FOR YOUR PATIENCE, UNDERSTANDING AND GUIDANCE!!!!!!!!!!!!
    • Winner Winner x 3
  16. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Simtools works, Utilities works, but game doesnt move the motors. My regional settings are correct..You seemed to of really tackeld the hell out of this issue, do you have any more ideas of what could be causing a failure in communication from the game to the motors? I'm using only one motor (roll). My axis in simtools is set at 100% with the box to the left shaded, although I might be messing something up here. In the interface settings I have all three axis assigned, though I have experimented with just using one ( [A<Axis1>] ). The arduino RX lights up upon game starting as if it's sending-receiving data. Any guidance here would me very much appreciated.
  17. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    So the SMC Utils moves motors fine? Simtool Axis testing is also fine?
    When launching game manager does it display it as Connected? If not then check your IP settings as game manager (if ran from the same machine like me) will be checking the game exe running on the specific IP address of the machine. This messed with me when the router decided to give me a new one :D.....
  18. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Yeah, both work fine. The game says it's connected. I dont use an IP, just a serial port.
  19. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    All games? When in game does Tuning Center value's change?
  20. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Negative
