RC Model for Motion Simulation
Discussion in 'SimTools compatible interfaces' started by eaorobbie, Jul 17, 2013.
  1. mariana fino
    mariana fino
    i am learning a lot about simtools with this rc model now 3dof ,simtools software its very good,nice work!!
  2. Jun
    Jun New Member
    South America
    7,048Coins
    You welcome. I'm glad that you get it work. I actually used "Sway" instead of "Extra 1" as Traction Lose because not all game plugins support "Extra 1" but should works without problem. :p
    http://www.xsimulator.net/community/faq/traction-loss.174/
    Cheers
    :cheers
  3. mariana fino
    mariana fino
    its ready,i have change axis assiment and replace rool and picth by sway and surge, then put extra 1 (tractionloss)in dof 3 and its perfect!!!for dirt 3,now just change some pluguns to put traction loss working i will post some fotos soon.ty again for the help,simtools its amazing!!state of the art software!!
  4. STR
    STR New Member
    223Coins
    SCN5, SCN6, 4DOF
    Thanks @eaorobbie excellent work saved me loads of time and money in dev
  5. stevemontuno
    stevemontuno Active Member
    1,461Coins
    Thankyou @eaorobbie ,,, Damn i feel like i've just had a major crash course in Ard+Simtools ,,,, I'm guessing that i've only just scratched the surface ,,,What a great way to learn the basics ,,,,,Cheers mate.
  6. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Thanks for your code @Jun, it allowed me to get into Arduino :).
    Now i would like to control the 3 servos with a floating Center Heave-Pitch-Roll architecture, have you developed the code for this type of simulator or is it just necessary to change the axis assignments ?
  7. Jun
    Jun New Member
    South America
    7,048Coins
    Just change the Axis Assignments. Good luck. :thumbs
  8. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Thank you very much @Jun :)
  9. Noph
    Noph New Member
    Bangkok
    224Coins
    DC motor
    Hello everyone and thanks for helping with the info. I am new to this fun hobby and I did finally made servos to work with Output testing on Sim Tools.
    But when I start running Live for Speed game, I received no signal from the game at all. Could you please tell ? I notice the Arduino's Rx LED is not lighting up when running the Game.
    151,991Coins
    +11,061 / 56 / -2
    Just checking have you patched LFS for motion in Game Manager?
    Please post some pictures of your model and all SimTools settings.
  11. Noph
    Noph New Member
    Bangkok
    224Coins
    DC motor
    yes please see.
    151,991Coins
    +11,061 / 56 / -2
    From the screenshots it does not appear as though you have patched LFS for motion in Game Manager. You use the Edit Path button to select the install folder for LFS then patch for motion.
  13. Noph
    Noph New Member
    Bangkok
    224Coins
    DC motor
    151,991Coins
    +11,061 / 56 / -2
  15. formek
    formek New Member
    turkey
    119Coins
    vaaav it is very useful thankss
  16. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    I'm looking for the Arduino code and schéma, for a 6dof RC model.
    I searched into the forum without result.
    Thanks in advance
  17. mariana fino
    mariana fino
  18. eaorobbie
    20,480Coins
    For true 6dof , simtools does not support yet , this will be coming toV2 with the addition of a special maths plugin I have been developing , as for model code , its simply adding 6 servos instead of 2, And all position calcs are done by simtools that way we can adapt 6dof control to any interface that simtools supports without the end user having to have a specially coded interface.
    • Informative Informative x 4
  19. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Merci eaorobbie , nous attendons avec impatience la V2 de Simtools :popcorn
    Thanks @eaorobbie, we're waiting impatiently the V2 of Simtools
  20. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    Noob question here. So according to the schematic the pwm output is driving the motor postion where as on regular DC motors pots are used for feedback, does this mean that for servos the software is assuming that motor actually moved to a specific angle? Thanks
