Hi all new to this
Discussion in 'New users start here - FAQ' started by Vdub180, Jan 21, 2016.
  1. Vdub180
    Vdub180 Member
    England
    148Coins
    Still pulling my hair out, put software on used the smc 1.6.7
  2. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @Vdub180
    You might want to get some kind of heatsink/cooling on the MM chips before you put it under to much stress.
  3. Vdub180
    Vdub180 Member
    England
    148Coins
    Need it to work first not sure if I'm using the right pots only getting 3v to motors
  4. Vdub180
    Vdub180 Member
    England
    148Coins
    These the correct pots
  5. Vdub180
    Vdub180 Member
    England
    148Coins
    I used the smc 1.6.7 software but didt make any alterations just up loaded as it was. No motors connected just tester to check voltages
  6. Vdub180
    Vdub180 Member
    England
    148Coins
    This look correct
  7. Vdub180
    Vdub180 Member
    England
    148Coins
  8. Vdub180
    Vdub180 Member
    England
    148Coins
  9. Vdub180
    Vdub180 Member
    England
    148Coins
  10. Vdub180
    Vdub180 Member
    England
    148Coins
  11. Vdub180
    Vdub180 Member
    England
    148Coins
    I'm still working on it maybe be more helpful the weekend
  12. Vdub180
    Vdub180 Member
    England
    148Coins
    Just a little update I have now got my rig working and it was a nightmare but thanks for all ur help hopefuly I can help some else in the future and pass on what u have show me so far. I have now taken my rig apart for alterations but waiting on post should be racing soon I'll up date with pics as soon as it running this has only cost me so far about 80 pound so I'm very happy
  13. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,445Coins
    You shouldn't really be changing the parameters in the code other than the #define MODE line.
    All user adjustable settings can be changed and tested with the Windows SMC3Utils.
    EDIT: To avoid confusion, there is no SMC3 version 1.6.7 - The 1.6.7 is the Arduino IDE version number.
  14. engenharia
    engenharia New Member
    Brasil
    231Coins
    the coil of the motor is electrically connected to housing , as you slip the two engines ?
    153,770Coins
    +11,149 / 57 / -2
  16. Vdub180
    Vdub180 Member
    England
    148Coins
    Hi all i thought after all the years ive been using my rig id share how its holding up and how it looks today, sill running the same mk4 golf wipers also
  17. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    looking good love the triples:thumbs
