Recent Activity
Activity stream for all registered members at Motion Simulator Community.
  1. arminglf liked Dirty's post in the thread Flypt Filter Research (or why doesnt my rig move right?).
    And now finally here we create those same curves directly in Mover :) [MEDIA] I think it should give you a great sense of satisfaction...
    Jun 18, 2024 at 05:03
  2. xFFBx Tearier liked Employee4Life's post in the thread 2DOF Steel frame 24v motors.
    It actually happened. It is done and working with LFS, ASSETTO CORSA and F1 23 Some fine tuning will be made. Have a look at the video...
    Jun 18, 2024 at 03:12
  3. noorbeast liked PhillyNJ's post in the thread Question SMC3 - Issues configuring motor.
    Thank you sir. This helped a lot. I set the following Fpwm - 25 PWMmin = 10 PWMmax = 90 PWMrev = 90 The motion is much much better and...
    Jun 18, 2024 at 02:13
  4. PhillyNJ liked Yinger's post in the thread Part help - Motor control arm?.
    I did a thing! I only have a drill press and some basic metal tools, BUT here are my new control arms. I bought a end mill bit and very...
    20240612_153618.jpg 20240612_153623.jpg 20240612_153621.jpg Jun 18, 2024 at 02:11
  5. PhillyNJ replied to the thread Question SMC3 - Issues configuring motor.
  6. noorbeast replied to the thread Question SMC3 - Issues configuring motor.
    Try Fpwm at 25.
    Jun 18, 2024 at 01:30
  7. PhillyNJ posted a new thread.
    Hi, I've been working on this issue for a few days. I am able to set the my motor's settings with SMC3. The motion is smooth, however,...
    Forum: DIY Motion Simulator Building Q&A / FAQ
    Jun 18, 2024 at 00:44
  8. Matthew Sibley replied to the thread 4 x 24v Motor and more.
    Hi buddy I'm confused are you selling for $200 if so I would like to purchase if you still have them Kind regards Matt
    Jun 17, 2024 at 23:24
  9. Eli Wizard replied to the thread 2DOF with wheelchair motors.
    Ha!,,, I had serial monitor on in IDE. now I'm cooking with gas. thanks for the pinout info
    Jun 17, 2024 at 22:03
  10. cfischer replied to the thread G-SEAT.
    The bottom frame that holds the actuators can flex a bit to account for the angle change. This was an experiment that worked but but...
    Jun 17, 2024 at 21:52
  11. Eli Wizard replied to the thread 2DOF with wheelchair motors.
    I have a little test bench set up with UNO(on COM 4), IBT, small 12v motor with a reduction gearbox and pot. Have edited SMCutils.cfg >...
    Jun 17, 2024 at 21:22
  12. dedraro replied to the thread 4 x 24v Motor and more.
    Hello I live in Italy This is the information I got from the ebay link: Operating voltage: 24 V No-load current: 10 A Maximum current...
  13. David muir replied to the thread Servo stops working.
    thanks for the info ,I’ll have a look at the weekend after work Cheers. Dave from Scotland
    Jun 17, 2024 at 20:14
  14. noorbeast replied to the thread motor 1 vs motor 2.
    You can use Output Testing in SimTools to check settings and should do so before messing with a game to ensure everything is properly...
    Jun 17, 2024 at 10:45
  15. noorbeast replied to the thread Are YOU a NEW MEMBER? Introduce HERE!.
    SMC3 has different code variations available for specific types of hardware, please see the FAQs here:...
    Jun 17, 2024 at 10:42
Loading...
