Recent Activity
Activity stream for all registered members at Motion Simulator Community.
  1. Eli Wizard replied to the thread 2DOF with wheelchair motors.
    Ha!,,, I had serial monitor on in IDE. now I'm cooking with gas. thanks for the pinout info
    Jun 17, 2024 at 22:03
  2. cfischer replied to the thread G-SEAT.
    The bottom frame that holds the actuators can flex a bit to account for the angle change. This was an experiment that worked but but...
    Jun 17, 2024 at 21:52
  3. Eli Wizard replied to the thread 2DOF with wheelchair motors.
    I have a little test bench set up with UNO(on COM 4), IBT, small 12v motor with a reduction gearbox and pot. Have edited SMCutils.cfg >...
    Jun 17, 2024 at 21:22
  4. dedraro replied to the thread 4 x 24v Motor and more.
    Hello I live in Italy This is the information I got from the ebay link: Operating voltage: 24 V No-load current: 10 A Maximum current...
  5. David muir replied to the thread Servo stops working.
    thanks for the info ,I’ll have a look at the weekend after work Cheers. Dave from Scotland
    Jun 17, 2024 at 20:14
  6. noorbeast replied to the thread motor 1 vs motor 2.
    You can use Output Testing in SimTools to check settings and should do so before messing with a game to ensure everything is properly...
    Jun 17, 2024 at 10:45
  7. noorbeast replied to the thread Are YOU a NEW MEMBER? Introduce HERE!.
    SMC3 has different code variations available for specific types of hardware, please see the FAQs here:...
    Jun 17, 2024 at 10:42
  8. noorbeast replied to the thread Servo stops working.
    How are the servos controlled, what power supply is used, please post pictures of all settings, and also let us know if there are any...
    Jun 17, 2024 at 10:40
  9. noorbeast rated hcee2022's post Informative in the thread (Yet another) 3DOF motion rig with g-seat for DCS.
    Hi @noorbeast, sure, here you go - some further info: The VPforce RHINO is a commercial FFB joystick developed and sold by a Lithuanian...
    Screenshot 2024-06-16 at 21.36.11.png Jun 17, 2024 at 10:36
  10. noorbeast replied to the thread Sim rig issues in vr.
    I don't have have game so can't check, but my guess would be there is a VR launcher file or flag. SimTools v3 makes it easy to set a...
  11. noorbeast replied to the thread 2DOF with wheelchair motors.
    The Sabertooth SMC3 code and wiring instructions can be found here:...
    Jun 17, 2024 at 10:04
  12. noorbeast liked Gefahren's post in the thread 3DoF G-Seat, All metal.
    Since I've disassembled everything to transfer the motors and such over to the new build it will take me a moment. I'll have to retune...
    PXL_20240617_035059536.jpg PXL_20240617_035121464.jpg PXL_20240617_034815942.jpg PXL_20240616_074222814.jpg PXL_20240616_074300906.jpg PXL_20240616_074313025.jpg PXL_20240617_034548917.jpg PXL_20240617_034624933.jpg Jun 17, 2024 at 10:01
  13. unpowde replied to the thread Question Any possibility to reduce the small movements?.
    As my opinion, adding some smoothing filters can help reduce the sensitivity to small step changes, which should in turn reduce...
    Jun 17, 2024 at 09:21
Loading...
