1st 2DOF compact build attempt
Discussion in 'DIY Motion Simulator Projects' started by maligator, Nov 18, 2014.
  1. maligator
    maligator New Member
    228Coins
    Guys, thank you for chiming in. I will be getting these 50:1 crab pot motors: http://www.ebay.com/itm/GEAR-MOTOR-...483?pt=LH_DefaultDomain_0&hash=item51bed470a3
    Are they power hungry enough to need 2x Motomonsters? Also, I agree totally on having spares on hand and will do that.
  2. Pit
    30,510Coins
    One MM should handle two motors, but the 12 bucks for the MM are like bird-do :) Take 4 of them (one in reserve and one for traction loss, who knows...) and you will be on the safe side.
  3. maligator
    228Coins
  4. RacingMat
    21,082Coins
    personnaly, I would only trust Cermet pot which are higher quality...
    I cannot see this item as well...
  5. Pit
    30,510Coins
  6. maligator
    228Coins
    OK, I'll get the cermet ones then, LOL
    Do they have to have 360* rotation? I found some that have 300*
  7. Pit
    30,510Coins
    300 or 360 is not the matter, more (or very) important is the fact you have to use the full turn of the pot. How much degrees you pot will have is part of your concept.
    PS: this statement not guilty for hall effect potentiometers.
  8. Nick Moxley
    17,057Coins
    spend the extra on Hall effects, Cheap Pots yield cheap results.
  9. bsft
    Or use expensive wire wound pots, like the $36 each ones I use as well
  10. Pit
    30,510Coins
    good pots are well-invested money - sooner or later (mostly sooner). cheap post are perishable (or food is perishable, don't know... ;P ) and sometimes the signal is jerky.
  11. Blame73
    Blame73 Well-Known Member
    8,314Coins
    If I understand it correctly at the maximum of the motor I should have the maximum of the pot, right?
  12. Pit
    30,510Coins
    better the maximum of the needed turn plus 20% or something around that. My motors can turn endless ;)
  13. Pit
    30,510Coins
    PS: why using the full turn: Ardunio knows 256 different positions. If you use much less positions, you have less positions for the needed turn, which makes the turn jerky (small steps between the positions). As far I know Pololu (jrks) are using a 10-bit resolution which should make less problems (but not confirmed by me, only hypothetical)
  14. maligator
    228Coins
    Can you suggest a good pot to look for? Thanks
  15. Nick Moxley
    17,057Coins
  16. maligator
    228Coins
    The two correct power supplies arrived today. Work schedule is tough this week so I'll start to get them modded when it slows down.
  17. Nick Moxley
    17,057Coins
    Are you planning a kill switch ? I personally went with Killing the power from the PSU which in turn causes an error in the JRK, Stopping any further motion.
  18. bsft
    yes, you need to stop the power going to the motors from the jrks, not stop the power going to the jrks
    • Disagree Disagree x 1
  19. Pit
    30,510Coins
    I think @maligator is using MMs.Killing the power from the PSU doesn't cause any issues.
  20. Nick Moxley
    17,057Coins
    No difference, Still stops the motion. and I would much rather have 24awg lead wires to control the power of the PSU than have to run 14awg wires off the motor leads to kill the power.
