2Dof, 120w, on ps5 and pc
Discussion in 'DIY Motion Simulator Projects' started by delahaye, Jan 8, 2024.
  1. ProjectF1
    ProjectF1 Member
    Electrician
    301Coins
    AC motor, Arduino, 4DOF
    thank you for all this information, I will try to put the same parameters as you, see if my simulator reacts better!
    I have another question, I use simhub to send UDP data from the PS5 console to simhub then from simhub to simtools, did you do it like that too?
    I will post a video of my 4DOF (1 DOF used for loss of traction)
    Have a good day !
  2. ProjectF1
    ProjectF1 Member
    Electrician
    301Coins
  3. delahaye
    delahaye Member
    143Coins
    I did that, but first start simtools, and be sure movements ok, and then start simhub.
    Working
  4. ProjectF1
    ProjectF1 Member
    Electrician
    301Coins
    It seems to me that I don't have the same settings as you on your photo 3793, what does this IP address 192 168 0 28 correspond to?
    (ip address of your PC?)
    THANKS
  5. delahaye
    delahaye Member
    143Coins
    Ou as tu 3793? Le port de fonctionnement f1 est 4123. Oui l'ip est mon pc.
    J'ai fais aussi une redirection de port sur ma freebox 4123 vers 4127 ( on peut pas utiliser le même port sur 2 applications). Mais à essayer sans faire ça. J'ai tellement tout essayé que la ça marche!
  6. ProjectF1
    ProjectF1 Member
    Electrician
    301Coins
    It seems to me that simtools is receiving data from the game (I see the cursors moving a little haphazardly in "virtual settings".
    I will try to set the same values as you (IP address, simtools parameters...) I will tell you if it is better!
    thank you again for your valuable help
  7. delahaye
    delahaye Member
    143Coins
    I think you have to put your real ip address, not internal 127.0.0.1
  8. delahaye
    delahaye Member
    143Coins
    You put 127... pc to pc, but ps5 is on your network, and have to communicate with ip 192....
  9. ProjectF1
    ProjectF1 Member
    Electrician
    301Coins
    ok I will change that this evening
    Thanks, have a good day
  10. delahaye
    delahaye Member
    143Coins
    Don't forget to put static ip on ps5 and pc, to have always the same ip adress when you start..
    Have a good day
  11. ProjectF1
    ProjectF1 Member
    Electrician
    301Coins
    Good evening Delahaye ,
    I tried to put the same settings as you, I don't have any data arriving on simtools...
    I reset my parameters, I have some values displayed on the tuning center but this one gives nonsense! they vary constantly while in the game my car is stationary.
    Can you send me a photo of the settings in the telemetry menu of the Game F1 23 on your PS5?
    can we see the values in simhub (pitch, roll...)?
    I think the game data is incorrect and sent incorrectly to Simtools...
    Thank you good night
  12. delahaye
    delahaye Member
    143Coins
    I, sorry for the delay.
    In f1 23, put your pc ip adress( real 192.168...)
    Port: 4123 ( port for the plugin f1 23 simtools)
    And in sim tools, put the ip adress of the ps5 ( 192.168... ) and 4123 port to.
    Be sure that is working. After that, you will configure sim hub.
    The problem is simhub have to read parameters from the ps5 too. And it's not possible on the same port 4123. You'll see after.
    Check f123 work fine with simtools first.
  13. delahaye
    delahaye Member
    143Coins
    When you start the game, go to simtools, and double click on play, ( stop in red coming) then clic one time on stop to stop the relation between game and simtools.
  14. delahaye
    delahaye Member
    143Coins
    I don't know if you put two fixed ip adress on ps5 and computer, it's important at this level...
  15. delahaye
    delahaye Member
    143Coins
    Do you download the good plugin f1 23 for console? And not for computer ?
  16. delahaye
    delahaye Member
    143Coins
    I see that you not put the real ip adress! Not 127.0.0.1 !
    it's the good plugin
  17. delahaye
    delahaye Member
    143Coins
    And just to be sure we are right together, simtools is used to move axles, sim hub for accessories ( dash, wind...)
  18. ProjectF1
    ProjectF1 Member
    Electrician
    301Coins
    hello delahaie,
    I just understood my problem! (the movements were completely random and were not at all synchronized with the game...)
    in fact, I sent my F1 24 PS5 game data as a priority to Simhub and from Simhub to Simtools:
    I think UDP data was "lost" between simhub and Simtools!
    so I sent my data directly to Simtools. the difference is enormous, I have regained good sensations of movement, everything is perfect now.
    I now use Simtools to send the data to simhub (because I use a phone screen to have a dashboard and display my parameters...
    you were of great help because I really had a lot of difficulty finding the right moves!
    A big thank-you!
    One last little question, I saw that you were French I wanted to know which region you were from? I live in Saint Étienne
  19. delahaye
    delahaye Member
    143Coins
    Great news! I live in Amiens between Paris and Lille
  20. delahaye
    delahaye Member
    143Coins
    For f1 23 i use thrustmaster tgt2 with sf1000 wheel with screen. I display on my dash screen only tires temp and map
