2dof 24v 250w wheelchair motors
Discussion in 'DIY Motion Simulator Projects' started by xFFBx Tearier, Dec 8, 2023.
  1. noorbeast
    153,884Coins
    +11,154 / 57 / -2
    Try dropping Fpwm on both motors to 25, then refine the settings for both.
  2. xFFBx Tearier
    xFFBx Tearier ffb Tearier Gold Contributor
    232Coins
    Received a new Ibt2 in the mail today and, boom. everything in Smc3 looks good, and both motors perform as expected. safe to say im good to move on to simtools?
  3. xFFBx Tearier
    232Coins
    and is everyone using simtools v3 or v2.6?
    153,884Coins
    +11,154 / 57 / -2
    SimTools v3 is at the tail end of Beta and is the best way to go if you are starting out, as it has the inbuilt repository for motion plugins and is all in one interface.
    That said, V2 and V3 can both be installed on the same computer, and use the same SimTools license, but v2 plugin access is separate and an additional cost: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
  5. xFFBx Tearier
    232Coins
    v2 works great! but has no plugin for MSFS 2024.
    so i went to boot into v3, and after following the set up instructions. i cant get any movement..
  6. xFFBx Tearier
    232Coins
    after unistalling both v2 and v3, and installing v3 again. i can get motion using the "test settings"
    but for pitch, only motor number 2 moves. and for roll, only motor 1 moves.. im at a loss
    153,884Coins
    +11,154 / 57 / -2
    Please post pictures of all of your axis assignments.
  8. xFFBx Tearier
    232Coins
    all fixed! I did not have the setting in the correct order!
  9. xFFBx Tearier
    232Coins
    Man this thing… took everything apart to solder. And now that it’s back together, as soon as I plug in the power supply. The rig start moving like crazy
    153,884Coins
    +11,154 / 57 / -2
    If it was working and is now not working you need to double check all wiring.
    Also redo settings from scratch.
    You likely need to also check the IBT2 functionality, as many members have reported quality control issues with them. While written with a different board in mind the fundamental process for checking is the same: https://www.xsimulator.net/community/threads/cheap-chinese-monster-moto-clones-and-problems.9059/
  11. xFFBx Tearier
    232Coins
    had to restart settings from scratch.. not fun.
    anyway to get warthunder to not launch through steam on sim tools v3? i dont have the game downloaded through steam.
  12. noorbeast
    153,884Coins
    +11,154 / 57 / -2
    SimTools v3 related questions should be posted to the dedicated V3 thread, for dev visibility, consideration and response: https://www.xsimulator.net/community/threads/simtools-2-to-simtools-3.19663/
  13. xFFBx Tearier
    232Coins
    i have had the rig up and running almost everyday now, for just over a week. Assetto Corsa, and Warthunder have never been this entertaining! I just want to thank everyone who has helped!!
