2DOF Arduino miniature motion platform w 2-servos
Discussion in 'DIY Motion Simulator Projects' started by jamesdio, Oct 13, 2011.
  1. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Hi!
    I found a solution to the problem with the servo shakes.
    Pause should be increased to 40 ms.
    • Disagree Disagree x 1
  2. JBoogie
    JBoogie Member
    Pre-sales Engineer
    Northern VA
    1,527Coins
  3. bsft
    @JBoogie , if you are happy with DERIYs solution, then you had better go to the forum of which the software that is posted in the picture belongs.
    Dont ask for help for x-sim software here.
  4. fireflyone
    fireflyone firefly's simulatior test build
    uk
    381Coins
    hi i have had a play with the code little not much as i am still learing set the output to hex and output bits to 10 bit instead of 8 kinda works better when i was seting up i had to move the sliders to - 70 to get the servo to work but if you change the above will work ok so dont shout i am still learning
  5. fireflyone
    uk
    381Coins
    /* i have added anothe servo fireflyone goint to add some more in min here is the updated code hope theis helps
    * 2DOF Motion Platform with 2 Servos
    * Thanks to herctrap and his source
    * http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1280139142
    * and also thanks to juiou and his source
    * http://www.x-simulator.de/forum/arduino-and-x-sim-t2773-30.html
    * I just combined their sources.
    #include <Servo.h>
    Servo myservo1;
    Servo myservo2;
    Servo myservo3;
    //Servo myservo1;
    //Servo myservo1;
    //Servo myservo1;
    int Degree;
    int Gforce = 0;
    int Gforce1 = 0;
    int Gforce10 = 0;
    int Gforce100 = 0;
    char kind_of_data;
    void setup() {
    //set servo pins
    myservo1.attach(2);
    myservo2.attach(3);
    myservo3.attach(4); //pwm servo
    //align servos center postision
    myservo1.write(90);
    myservo2.write(90);
    myservo3.write(90);
    //open serial connection
    Serial.begin(115200);
    void loop() {
    // wait for serial input (min 3 bytes in buffer)
    while(Serial.available() > 0) {
    kind_of_data = Serial.read(); //string from USO --> L~a01~ R~a02~ 8bit resolution\decimal output
    if(kind_of_data == 'L') {
    Read_Pos(kind_of_data);
    if(kind_of_data == 'R') {
    if(kind_of_data == 'F') {
    void Read_Pos(char which_servo){
    delay(2);
    int Gforce100 = Serial.read()- '0';
    delay(2);
    int Gforce10 = Serial.read()- '0';
    delay(2);
    int Gforce1 = Serial.read()- '0';
    //Verifica se e centena dezena ou decimal... =]
    if (Gforce1 < 0) { Gforce = Gforce10 + 10*Gforce100; }
    if (Gforce1 < 0 && Gforce10 < 0) { Gforce = Gforce100; }
    if (Gforce100 < 0) { Gforce = 127; }
    if (Gforce1 >=0 && Gforce10 >= 0 && Gforce100 >= 0) { Gforce = 100 * Gforce100 + 10 * Gforce10 + Gforce1; }
    if (which_servo == 'L') {
    Degree = map(Gforce, 0, 255, 180, 0);
    if (which_servo == 'R') {
    Degree = map(Gforce, 0, 255, 0, 180);
    if (which_servo == 'F') {
    myservo1.write(Degree);
    if (which_servo == 'R' ){
    myservo2.write(Degree);
    if (which_servo == 'F' ){
    //just edit the axis and keep adding L<Axis1>R<Axis2>F<Axis3> as i am making 3 dof sim i do still need help thanks all out thare from fireflyone@me.com
  6. eaorobbie
    20,491Coins
    because of the code this contains delays which is not a good way to control ultra quick servos. Please take a look at this code I develop with the help of @aarondc. Its way faster and can be made into 6dof code very easily as @Historiker has shown with his 6dof model.
  7. bsft
    i am not shouting............yet
  8. eaorobbie
    20,491Coins
    How did it go @fireflyone , Im willing to mode my code for you to 3dof if needed mate. Let me know.
  9. fireflyone
    uk
    381Coins
    please this would be great help i am using 2 monstermoto sheilds and ither adruino uno or mega that would be the eassy way for you i plan to get some more pics on later to do some testing so i will soo how it goes my email is fireflyone@me.com sorry for the typing its coold fingers geting slow thank you
  10. eaorobbie
    20,491Coins
    Ah sorry I dont use ard to control H bridges found the motion to be poor compared to Jrks I use so I dont bother but as a dashboard or used to run a RC model of a sim , they perform very well.
  11. 362442340
    362442340 New Member
    328Coins
    i can't control the servo by use this code for 4dof
  12. 362442340
    328Coins
    can you tell me the simtool setting///thankyou'。
  13. Capitan
    Capitan New Member
    202Coins
    hello a question you code works well used? I'm just back from doing one servor to test the system to see how it works for then launch into the simulator on a large scale.
