2dof motors shutting down
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Killertbone6, Sep 6, 2025.
  1. Killertbone6
    Killertbone6 New Member
    62Coins
    Noorbeast sorry if I gave bad advice.
    However I did try manually removing the plugin previously and it did not work. Deleting all Simtools files was the only thing that worked for me as even uninstalling Simtools the normal way did nothing.
    This is just what happened in my experience, but I can take down my previous reply if you think something bad could come from it.
    154,750Coins
    +11,196 / 57 / -2
    I am not criticizing yourself @Killertbone6, just pointing out that deleting any search result labeled SimTools may corrupt the install, in circumstances where it likely is just a plugin issue.
    Worst case SimTools can always be removed ad reinstalled to reset everything to defaults.
  3. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    170Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    Hooray! I solved the problem by removing the previous language settings I made for SimTools 2.5...
