2DOF Seat Mover - First Build
Discussion in 'DIY Motion Simulator Projects' started by The ORDL, Jun 22, 2024.
  1. The ORDL
    The ORDL Member
    489Coins
    Ah, @Gefahren that makes sense now you explain it like that!
  2. The ORDL
    The ORDL Member
    489Coins
    Some more progress today!
    I now have the pots soldered up and heat shrunk in place, just need to decide where the Uno will be mounted. I think just behind the motors will work nicely
    Ive also moved the IBTs to the front of the frame, the motor cables reach here and with the PSUs, I can run a fan to them easily.
    Mounted the power supplies using custom 3D printed brackets that work really nicely. With the connections to the front of the frame I can wire into the IBTs quite easily here. I just need to print some covers for the connections.
  3. The ORDL
    The ORDL Member
    489Coins
    Started wiring everything up, just need to decide on Uno placement now. GT2 pulleys and fans for the IBTs alao on their way.
    @Gefahren 2 wires to IBTs from power supply as suggested in pics
  4. The ORDL
    The ORDL Member
    489Coins
    Before I start more soldering tomorrow, just to confirm that these 2 pins on the IBTs are joined back to the Uno?
    151,979Coins
    +11,061 / 56 / -2
    This is the full wiring for IBTs, can you please clarify what you mean:
  6. Gefahren
    Gefahren Member
    Electronics Engineer
    Central Mississippi, USA
    395Coins
    Per the diagram the R_EN and L_EN signal on the IBT are tied together and go back to a single pin on the Uno.
    Don't forget to program the Uno for the correct Mode. Also, I'd suggest testing it before you mount anything that can mechanically bind up.
    You should have two wires for + and two for - on the power connection. Looks like you used an old power cord for that, sometimes the three wires are not all the same size in those. Although I usually don't use it, speaker wire is a good source for heavier gauge power wiring that is usually less expensive.
    The base looks nice and clean. I would suggest some sort of cover for the screw terminals on the PSU's.
  7. The ORDL
    The ORDL Member
    489Coins
    Thanks guys, yes Noorbeast, I meant 3 and 4 on the Uno tied together.
    I will have a look at other wiring too, see if I can find something better.
    The PSUs will get 3d printed covers for the terminals, I just need to design them up with the openijgs for cables.
    The programming for me will be the hard side, Ive seen I need to set mode 2. Il be running the 3D printed arms for testing before mounting the joint and top seat section.
  8. The ORDL
    The ORDL Member
    489Coins
    Bit more progress, I redesigned the IBT mount to incorporate a 24v fan 80mm. Il also print a cover for the bottom to tidy up the wiring and also still need to print the PSU covers.
    Wiring almost done and my motor pulleys have arrived. The 200mm belts werent big enough so just waiting on some 230mm to arrive.
  9. The ORDL
    The ORDL Member
    489Coins
    My custom mount for the 7960s inc the fan and bottom cover are now on Thingiverse if it helps anyone out. This is an edited version of another IBT mount to begin with, cant remember whos so please credit if you come across them.
    Hole spacing for mounting to aluminium profile is 150mm, but I am sure this could be edited to suit.
    https://www.thingiverse.com/thing:6711354
  10. Gefahren
    Gefahren Member
    395Coins
    Looks nice and compact but seems like it would be a pain to try adjusting any of the wiring plugged into the Arduino. I wonder how susceptible the Arduino is to the radiated noise from the motors, it is right under the end where the brushes are.
  11. The ORDL
    The ORDL Member
    489Coins
    Hey guys, been a while. I've had my mum in hospital due to cancer, and my dad in hospital due to covid/had a stroke. I am hopefully getting the motor arms next week and we can finally get this rig rolling, with a little help :)
    • Friendly Friendly x 2
  12. noorbeast
    151,979Coins
    +11,061 / 56 / -2
    Our thoughts are with your family and of course they take precedent over projects, but great to have you back and I look forward to following your future progress.
  13. Jango
    Jango Member
    Mauritius
    380Coins
    2DOF, DC motor
    Hi there, hope your loved ones recover fast.
    yesterday i started receiving my parts for my build - i tested the power supply 2 units of 24v 20A with fan cooling. And they were making usual fan noises - i'm checking this forum on noise levels. Not sure if i'll return these units and get passive cooling ones. Not sure which other parts will generate new noise...
    I'll start my thread once i receive all parts.
  14. The ORDL
    The ORDL Member
    489Coins
    Thanks, guys, we are getting there. On top of everything my wife also had an operation today to add to the stress, all is ok so hoping to crack on. My friend Alex is CNCing the arms for me, he will be away until the 16th of Sept so I have some time to wait until he is back.
    Alex is known for his custom PC work, something I also do in my spare time, if you like watching CNC-related vids, I recommend you check him out.
    https://www.youtube.com/praetexdesign
  15. The ORDL
    The ORDL Member
    489Coins
    Hey guys, been a while!
    Jumping back on to get this thing up and running, so still need your assistance if you may! Last year was challenging to say the least, my wife had an operation, my mum died, and my dad had a stroke, all within about 3 months, so this had to go on hold sadly.
    I'm going to drag the rig out, dust it off and try to get back up to speed with it over the next few weeks. I've been putting together daily YouTube racing videos, some POV content, so I am hoping the motion rig will help really set off the final effect on camera.
    Il post up in a couple of days once I have figured out where its at and hope that by the middle of summer it will be all done and ready to race with finally!
  16. obcity
    obcity New Member
    - 24Coins
    Hello.Which pulleys do you use?70-16?
  17. The ORDL
    The ORDL Member
    489Coins
    Well, finally we have some motor arms!
    My good friend at Pratex Design has CNC cut the arms to my spec, so hopefully we can crack on with getting this finished soon. I would highly recommend Alex, see what he does here:
    https://www.youtube.com/c/praetexdesign/about
