2dof simulator
Discussion in 'Motor actuators and drivers' started by TomSim, Feb 12, 2025.
  1. TomSim
    TomSim Member
    192Coins
    I think it could be torsional twist, that would make it move side to side too. I need to attach frame to some thick plywood, that will rule out that torsional twist.
    154,675Coins
    +11,209 / 57 / -2
    Side to side could mean cross bracing is needed but up and down is a surprise, given you gave it this test:
  3. TomSim
    TomSim Member
    192Coins
    up and down is very little so that can't be noticed when driving...it's more like vibrating. Where should I add cross bracing? Now that I have drive sometime I noticed that the flexin is only when ff is turned very high.
    154,675Coins
    +11,209 / 57 / -2
    Without actually seeing it makes it hard to say for sure, so perhaps use some bolt on bits to test bracing ideas, here is one:
  5. TomSim
    TomSim Member
    192Coins
    That is just what I was thinking myself but that kind supporting beam will make hard to get in and out of rig...maybe right side that would work. I also have think to add bolted supports to test what would work best so I'm same page with you on that.
