2dof to 3dof DIY Seat mover
Discussion in 'DIY Motion Simulator Projects' started by Nick Moxley, Mar 3, 2014.
  1. jimmytm3
    jimmytm3 Member
    Boilermaker
    macksville, New South Wales Australia
    171Coins
    2DOF, Arduino, JRK
    Wonder how traction loss would be if the monitors and all moved at the same time, As my rig could only be modified in that way . pity i made it so bloody heavy
  2. Nick Moxley
    17,057Coins
    TL with moving monitor's would be a no go imo. Static racer's use the Visuals to know they are sliding in conjunction with wheel FFB and sounds....but the Visuals play a big role in feeling of TL and thats the same for with Motion.
  3. Historiker
    Michigan USA
    9,214Coins
    @jimmytm3 My whole rig moves with traction loss. I like it.
  4. jimmytm3
    jimmytm3 Member
    Boilermaker
    171Coins
    2DOF, Arduino, JRK
    Hey mate so your traction loss is a 25:1 gearbox
  5. Nick Moxley
    17,057Coins
    Correct. debatable whether or not a 50:1 would be better for its Overall Torque/holding power and ability to not "free run"
  6. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
    i've 500W motors with attached gearboxes which deliver 30 rpm/min. this is 180° movement in 1 sec.
    do you guys think this is fast enough ?
    Best,
    Oliver
    152,971Coins
    +11,115 / 56 / -2
  8. kermitkong
    1,240Coins
    very helpful thanks !
  9. Nick Moxley
    17,057Coins
    So After finding a Smoking deal on a pair of motor's another member on the site is using, I decided to pick up a pair. (40$ + 30$ shipping) and I also picked them up while racing down south to save on Duty.... cha ching.
    Got them home and popped them open to find a Gorgeous Spiral cut circle grooved Ti Nitride coated main gear off the motor shaft followed by Uber beefy Steel gears for the lever gears. Took a bit of work to get the Stock grease removed, But a few dozen paper towels, a toothbrush with some Iosol and some blasts with the compressor and she's all clean and ready for a re greasing. I'll make up a set of plates to close up the gear box and use the 4 outside holes for mounting to a plate of sorts.
    • Like Like x 6
    • Winner Winner x 3
  10. Nick Moxley
    17,057Coins
    Needed some Pot mounts on the new motor's.....Popped off the bearing seal to find a nice countersunk 1/8 hold asking to be drilled and tested for harness....Guess what, NOT hardened. Awesome so the drilling began after choosing a nice strait 1/4 bolt shank to work with.
    Prepped for drilling
    Drilled, tapped and mounted.
    Plexi covers
    • Like Like x 5
  11. Nick Moxley
    17,057Coins
    Project F paying 89 Euro's for an adjustable mount when i don't need any adjust ability = Success.
    1x1 square with an edge taken down....easy peeezy.
  12. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Nick, Excellent job on the motors pot?
  13. Nick Moxley
    17,057Coins
    Correct Milton, After you mentioned the welding you did to get your Pots installed, I thought about trying to drill the shaft and got lucky these aren't Super Duper Hardened steel gears. Im now thinking i might use these for a Heave project instead of another rig in the future....haven't decided.
  14. noorbeast
    152,971Coins
    +11,115 / 56 / -2
    Heave is an excellent addition and you could always cannibalise them later for another rig.
  15. Nick Moxley
    17,057Coins
    Add in @Pit style Hinged plate and i could make it relatively easy....Only problem is I dont have room to go Down with the plate, only Up....That is unless i figure out a different place to mount my Mechanical frame stops for the TL. But that might lead to other issues....hrmm...the brain storming begins....:think
  16. noorbeast
    152,971Coins
    +11,115 / 56 / -2
    Where there is a will there is a way :grin
  17. Nick Moxley
    17,057Coins
    As discussed earlier, The plastic coupler's could be a little better in design.....I finally got around to adding the last steel coupler on my TL motor but ran into a slight issue, somehow the small 4 black bushing's were Overly small/sloppy in this set of the steel couplers VS The Stock plastic one's......So i came up with a Pin/Fuel tubing solution....Fuel tubing from RC cars is ridiculously strong stuff and will serve this job perfectly and the pins were just some 11.6mm drive pins i shortened to the required height.
    PS Shoe goo wont stick to silicone tubing no matter how much you apply....Lol So I used some CA aka Superglue/Tire glue/Cut yo Finger quick repair glue, ect ect.
    • Creative Creative x 3
  18. Sebj
    Sebj Active Member
    Canada
    492Coins
    Nice design. If mine ever go I will have to revisit this post and get some help :)
  19. Nick Moxley
    17,057Coins
    If you plan to run them as hard as i do, It wouldn't be a bad idea to have on hand for when you do your first grease job(after a year or 2) and find some slop/play in the plastic units.
  20. Nick Moxley
    17,057Coins
    So i had a Catastrophic failure of a bearing on the worm gear shaft on my Right seat motor last night. Felt a Gritty feeling while in the seat and decided to shut down and inspect. (good thing too).
    Turns out the Bearing that lost its seal a while back(year plus) had 100% come apart. Luckily there was no damage to the worm gear or the nylon main gear. I proceeded to try and remove the Inner Race of the bearing But it proved to been rather seized on there, With multiple heating and cooling phases and trying to Punch the worm gear shaft out of the Inner race, I eventually decided to Take a Very thin cut off wheel and slice the race off. Once removed I "borrowed" a bearing from Buddy's motor's and went about re installing.
    Im not too sure exactly why the bearing came apart as it did. Maybe the Larger style bearing's used in these boxes with metal shields very much Require the shield to keep them together, where as the Micro bearing's i deal with on my RC cars dont. I can remove a shield and the bearing performs as normal.
    Either way, 1 more thing learned and dealt with. Spare bearing's will be ordered asap.
