2dof-wiper-motor-car-simulator-by-DERIY-(SATO)
Discussion in 'DIY Motion Simulator Projects' started by DERIY, Apr 26, 2010.
  1. ruiaircraft
    ruiaircraft New Member
    Hi DERIY,
    what did you use as Servo Motor Amplifier Controller to work with a DC wiper motor ?
    thanks
  2. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
  3. John05
    John05 New Member
    - 19Coins
    Hello Deriy, Thank you for posting the info for building your simulator.However, the problem that I have is trying to enlarge the drawing of the wiring of the RN-VN2 Controller and the wiring of the Polulu driver.
    Thank you
    John
  4. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Sorry John, I do not understand the question.
    What is it RN-VN2 ?
  5. wimpo`
    wimpo` Member
    metselaar
    nederland, twente, vroomshoop
    178Coins
  6. John05
    John05 New Member
    - 19Coins
    Hello Deriy, I am referring to the wiring drawings that you posted for the controllers. The drawings are too small and I cannot enlarge them to read them.
    John
  7. xiaoshi
    xiaoshi New Member
    Hello everybody
    I am a Chinese fan, like here, but also admire your ability to innovate.
  8. gaf00tas
    gaf00tas New Member
    Hello Deriy, congratulations for your great work.
    Can you explain and share pictures of your assembly
    potentiometers?
    What part of the movement of the seat?
    Greetings from Spain
    Greetings from Spain...
  9. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Hi gaf00tas!
    This Potentiometers photos.
    I installed them so that they do not control the position of the engine. They control the position of the platform. Very reliable method of installation.
    In contrast to the way the shaft gear.
    It has been five months since the launch of my simulator.
    And never Potentiometers did not disappoint me.
    If I'm not mistaken, you're asking about this thing
    This is a ball bearing from the vehicle.
  10. gaf00tas
    gaf00tas New Member
    that's what I wanted
    thank you very much, I want to build one like you.
    wiper motors that are voltage?
    they are to bear my weight of 118 kg
  11. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Voltage on motors 16volt.
    My weight of 112 kg, despite this, the motors are very briskly move the chair.
    Most importantly, well-balanced platform. Find center of gravity
  12. adlan911
    adlan911 New Member
    Deriy,
    u really are genius.
    alan from Malaysia
  13. gaf00tas
    gaf00tas New Member
    Hi, i need plans, layouts and dimensions...
    Have you this?
    Regards
  14. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
  15. uncels
    uncels New Member
    Drive-Instructor
    Netherlands (NB)
    485Coins
    Very nice job & cheap made as you say. Nice craftmanship. Did you tested it on rfactor ?
    Greetz from the Netherlands.
  16. dno180
    dno180 New Member
    Deriy what part of vehicle is the ball bearing from?
    Thank you for creating a great design
  17. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Unfortunately I am still not able to test my sim in the game rfactor .
    But I have no doubt that my simulator it will work just as well, as in other games.
    This detail on it sways the whole structure.
  18. fredspeed
    fredspeed New Member
    Northern Norway
    418Coins
    Hello Deriy. I am impressed of your work! I will use ideas from you in the sim I am building. You wrote that the voltage is 16v What kind of power supply or battery are you using? Are the motors 12v vipermotors? (looks like it)
    Fred
  19. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Hi Fred!
    I use a homemade power supply at 16 volts.
    Wiper motors at 12 volts.
    They work fine with this voltage.
    ps. Good luck in building a simulator!
  20. fredspeed
    Northern Norway
    418Coins
    Homemade power supply! wow! another diy project maybe... Thanos recomended someplace here a car battery, because that prevented overheating of the mosfets (Dont remember where) Is your h-bridge working fine? you know any type of power supply that can be used?
