2dof-wiper-motor-car-simulator-by-DERIY-(SATO)
Discussion in 'DIY Motion Simulator Projects' started by DERIY, Apr 26, 2010.
  1. bsft
    Well done! Thats great to see the rig on a show like that! Congratulations! :clap:
  2. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    I recently ordered a new steering wheel CSR-Elite, and pedals Fanatec Clubsport, and installed on my simulator.
  3. floriske.nl
    floriske.nl Member
    Graphic Designer
    Netherlands
    27Coins
    That's a nice setup! Wish I had the funds for that ;)
    First off: compliments on your build! Looking very solid and compact and is definitely an inspiration for a lot of us I think!
    Hopefully you won't mind me asking a few questions:
    • Can you tell me how much clearance you have between the 2 platforms? (base and moving platform)
    • Do you have any pictures of the attachment of the chair base to the platform? Did you use some sort of ball joint for this?
    Thx in advance! And once again compliments on the build!
  4. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    20cm distance from the base to the moving platform.
    This is a ball bearing from the vehicle.
  5. av8tr
    av8tr New Member
    Wow,
    Awesome build. She's definitely a beauty. I started building a unit using Skyrider chassis design, however although
    I understand the electronics I have no experience with the motor controllers. I'd love to use wiper motors instead
    of actuators because there so much cheaper, but I'm sure how to control the motors. I just bought a K8055 controller and the small relays to control the motors, but not sure about the positional feedback etc.
    Would you share the info on the electronics for the motors ??
    Thanx and nice job, Jurgen av8tr@sympatico.ca yup I fly for real as well..
  6. poteroa
    poteroa New Member
    Service Technician
    Finland
    Hey Deriy!
    Nice, very nice platform. You have a lever on the right side? Handbrake for ease drifting?
    Very cool packet. I think I will go for something similar.
  7. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Yes, this is the hand brake.
    Made from 15mm plywood.
    Instead of springs, i used a piece of rubber.
    Another used reed switch and magnet.
    After replacing the steering wheel and gear, had to redo the parking brake.
    I used the PS3 controller. The right analog stick now performs certain functions handbrake.
    I also set the vibrating motor in the handle of the hand brake.
  8. bsft
    Hey thats great work! Love the handbrake.
  9. Claudemir
    3Coins
    hello to all the forum, hello Deriy sorry for the typos I'm using google translator. the good times I'm trying to do this one you already have made ​​the cockpit engines cleaner to breeze almost done this more the question is, who do not know whit of electronics, mechanics know much more. then I would like some tips on how to make the connections with the motor plate, and By the way as I said I know nothing about electronics more I learn fast, as here has these components to make the card I found this board ready to sell on the Internet and would you descend a look, and tell me if this board will serve to make this automation is plaque (http://www.botnroll.com/product.php?id_product=268) is the name of this board (Wild Thumper Controller Board - ROB-11057) please help us! here in Brazil does not have that can help me I'm looking at a year, the DES already very sheltered.
  10. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Project CARS gameplay.
    As a plugin for this game has not been written, had to compromise.
    In this case, to control the chair used by the team coming from the steering wheel and pedals.
    Profile in XSim3 is configured so that when you turn to the right, the chair tilts to the left, and vice versa.
    When you press the gas pedal, the seat tilts back.
    When you press the brake, the seat tilts forvard.
    Also the profile configuration option is used sine washout, which gradually returns seat in the neutral position, even if the steering wheel or the pedal is in the end position.
    Of course, this way of implementing congestion effects can not be called perfect, but even with this approach, the effect of immersion in game play, increases many times.
  11. bsft
  12. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    bsft, Thank you very much for the information!
    Indeed, the plugin works fine.
