2DoF Wiper Motor Uno MM
Discussion in 'DIY Motion Simulator Projects' started by DonCorleonez, Aug 26, 2016.
  1. DonCorleonez
    DonCorleonez Member
    195Coins
    Actually, for profiling i am using M3 GT2 at Monza track, what do you think?
    And for Dirt Rally, what is your opinion for basing (car & track?)
    noted for profile editor @Nick Moxley :thumbs
    153,788Coins
    +11,150 / 57 / -2
    The only real set up difference from SimTools 1.3 to SimTools 2.0 is that instead of axis defined like this <Axis1> it is now has a designated grouping for a or b like this: <Axis1a>
    You will have to add the a grouping for each axis in the Interface settings.
  3. Nick Moxley
    17,057Coins
    IF GT2/3/4 is your comfort zone, then monza is a good track for surface details, Not so much for overall profile tuning including some Pitch and roll in the track** For that I would vensture to Spa or Imola has some very nice pitch/roll changes to show off the profile a little more. VIR Virginia International Raceway (mod but Kunos level quality HIGHLY suggested) Is another great track to feel some High speed pitch moments on the big back stretch.
    Dirt rally i spend 99% of the time in the Lancia Delta Integrale, Im not a fan of most of the Suspension geometry's used in Dirt and unfortunatly Dirt4 hasn't looked much better in the beta footage ive seen. :(
    Edit, DO NOT use the nords for any baseline profile setups. Very keen motion guys will pick up on something very unique to the nords that has to be accounted for.
  4. DonCorleonez
    DonCorleonez Member
    195Coins
    i am sorry that title is misleading, actually in progress i changed from wiper to worm motor from motion dynamic and also change from MM to sabertooth
    is there anyway to change thread title @noorbeast
    153,788Coins
    +11,150 / 57 / -2
  6. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    Hallo,
    Did you solve the PSU shutdown caused of back current? Can you please explain me how?
    gigi
  7. DonCorleonez
    DonCorleonez Member
    195Coins
    Hi @gigi , yes after PM-ing @Wanegain about this issue, he came up with solution. The solution is lowering the amp to 30A for each channel in sabertooth describe software under Output Tab.
    After that there's no more PSU Shutdown.
  8. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    Thanks i'will try
