2DOF Wiper Sim from Interview 2010
Discussion in 'DIY Motion Simulator Projects' started by Deleted member 4120, Oct 1, 2010.
  1. Deleted member 4120
    Deleted member 4120
    hmm is it better then thanos controller...? and what i need for equpment for the polulu controller?
  2. Deleted member 4120
    Deleted member 4120
    i need rfactor, lfs, dirt2, iracing... grt2.. can i play this all polulu?
    (i think whit x-sim i can )
    @FRAKK what do you think I should try again and all the parts for the h-bridge now and again solder?
  3. Frakk
    Frakk Active Member
    328Coins
    Your questions have already been asked, and answered.
    I told you to use Pololu from the beginning, but no, you just didn't listen! :D
    You could have saved yourself a couple months of headaches....
    Making a new dMSHB is not going to solve it's design problems. I would wait for Thanos' next h-bridge, or get a Pololu.
  4. Deleted member 4120
    Deleted member 4120
    :D:D oooo yess thats right^^ but im not a billionär :(
    polulu for what if I already have tronic finished... (h-bridge only damn!! :(
  5. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Thanos hbridge support up to 24Khz pwm without problem ( i have test it up to 30Khz with my controller and its still working). Polulu motor driver like MD03A limit to 20khz only. but who cares bro? make you own decision. sharing our fun and satisfaction are the only reason we all are here. video shown in my thread mostly use 10Khz PWM only.. :)
  6. Frakk
    Frakk Active Member
    328Coins
    I would put a scope on those MOSFET gates before I say they work without problem kubing. :)
    Interview: you can still use the AMC for the main controller, only use a different motor driver.
  7. Deleted member 4120
    Deleted member 4120
  8. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    If you already built AMC, you can use MD03A..cheaper. :D
  9. Enrico1230
    Enrico1230 New Member
    Österreich/wien
    485Coins
    Hello
    Sry.ich myself am a beginner, but as to me is the question
    to what may be last but finally? who has already viewed the placement list of H-bridge is perhaps because of the error?. Because many users use this H. Bridge, and since it transmits yes.
  10. Deleted member 4120
    Deleted member 4120
    now almost all have done.
    I mounted the long poles to my wiper motors.
    and noticed that they move to the ax back and forth.
    did you even play in your ax at the wiper motor?
    :sos:
  11. Deleted member 4120
    Deleted member 4120
    hello,
    today I share my, for my broken h-bridge to get!
    before I unsolder everything I have just replaced the MOSFETS.
    conclusion:
    far funktoiniert all ...
    maybe only the mosfets are burned.
    I hope this will continue to work towards.
    Today I will make the cooling fins:)
    NEXT TIME PICTURES FROM MY 2DOF SIM AND MY NEW BLACK BOX
    ..... have fun;)
  12. Deleted member 4120
    Deleted member 4120
    update:
    I've just found out that when I connect a motor to number 1, he does all the time without problemm.
    and the port number 2, I move it to the potimeter few times back and forth and then does not move the motor.
    one mosfet is a very hot
    can you help me please ..
    BIG THX
    picture:
  13. Frakk
    Frakk Active Member
    328Coins
    The only way we can help is to completely re-design the MOSFET driver circuit and you build the new board.
  14. Deleted member 4120
    Deleted member 4120
    PAGE ONE HAS BEEN UPDATED!!! 21.01.2011
    have fun!
  15. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    what update?
  16. Deleted member 4120
    Deleted member 4120
    Update:
    where you can buy power supply:
    - Transformator (POWER SUPPLY) http://www.smd-light.de or http://www.ledhome24.de/ better at ebay search: LED Transformator
    and
    shopping cart:
    - Tronic's AVR MotionController v1.5 Parts: http://www.reichelt.de/?ACTION=20;AWKID ... ROVID=2084
    - Simple dual H-bridge PCB 1.2b parts: http://www.reichelt.de/?ACTION=20;AWKID ... ROVID=2084
    - NOT FORGOTTEN!!! (missing in the shopping cart please do not forget to order with) 20x http://www.reichelt.de/?;ACTION=3;LA=50 ... SORT=artnr
  17. Deleted member 4120
    Deleted member 4120
    hello,
    today I got my first running test done.
    I've noticed that when I put on my board SFGT it only works if I create a JoyR Profile
    I have 6 hours of use until I noticed that: D
    why is that?
    (if I put it on SFGT area and a profile for SFGT create.
    and if I drive it, moving at slow speed and only one engine, the other motor moves only when I go into the curves.
    I have completed what might wrong?
    THANKS
  18. Deleted member 4120
    Deleted member 4120
    I found out that it is on JoyR dip!
    SFGT work and JoyR not!!!
    plz help :sos:
  19. Deleted member 4120
    Deleted member 4120
    :) my 2DOF project is completed wiper ...
    i drive two weeks whit my motion.
    it was verrrry funny ...
    but now i sold my controller and parts.
    I have built me a little sim without movement.
    (with ButtKicker)
    It makes a lot of fun but I'm just wondering about if I buy the scn5 soon and build me a new simulator.
    (pictures of my old and now I shall be clean place soon.)
  20. Deleted member 4120
    Deleted member 4120
    hallo Leute,
    hier mal ein par Fotos von meinem SMART-Rig ;)
