2DOF Wiper Sim from Interview 2010
Discussion in 'DIY Motion Simulator Projects' started by Deleted member 4120, Oct 1, 2010.
  1. Deleted member 4120
    Deleted member 4120
    Re: Wiper Motion Projekt Protocol by Interview 2010
    sicher das sie spiegelverkehrt nicht funktionieren??
  2. Deleted member 4120
    Deleted member 4120
    I now get the right boards. ;)
    and I have the H-Bridge soldered ready ..
    4 holes are left??
    what do in there?
  3. Jeroen
    Jeroen DoctorXeno
    Holland
    - 71Coins
    Nothing should be placed in those holes
    Gr Jeroen
  4. Deleted member 4120
    Deleted member 4120
    why the holes are then on the layout?
  5. Jeroen
    Jeroen DoctorXeno
    Holland
    - 71Coins
    You used an old layout...
    gr. Jeroen
  6. Deleted member 4120
    Deleted member 4120
    no sorry!! i have the last version of the H-Bridge !!
  7. Deleted member 4120
    Deleted member 4120
    hi guys,
    in my AMC board i have free holes.
    But the amc and the h-bridge layouts are up to date.
    need help
    thanks
  8. Frakk
    Frakk Active Member
    328Coins
    Why are you so worried about a couple extra holes?
  9. Deleted member 4120
    Deleted member 4120
    I am a perfectionist:)
    I have a lot of trouble to look for the latest layouts, where everything is so perfect ...
    and now there are holes free! (And I do not know for what the holes are.)
  10. Frakk
    Frakk Active Member
    328Coins
    Ok, well, look at the back of your board. Look at the board layout.
    Those holes are labeled J?, meaning jumper. I don't know what was the original intention, but the jumpers would connect those lines somewhere else, most likely for debugging or some additional circuitry that is not used.
    Just ignore them and carry on.
  11. Deleted member 4120
    Deleted member 4120
    :) okay frakk thanks
  12. obisk
    obisk New Member
    tot suchen hier im forum
    Kalsruhe
    what gears should I use for the translation? (Multiturn pot 10k ohm)
    thanks
  13. Deleted member 4120
    Deleted member 4120
    I've heard that a 1:20 Translation is the best!
    whether the proof I wrong!
    I know many just do a 1:5, 1:6 Translation ..
    :) Frakk what you say? which is better?
  14. Frakk
    Frakk Active Member
    328Coins
    I already posted this a couple times:
    Keep it simple: Use a good quality, single turn 270° potentiometer, 10Kohms.
    If you have 20 turns, the wiper has to move 20x faster, creating more heat and friction, wearing out faster.
  15. Deleted member 4120
    Deleted member 4120
  16. Deleted member 4120
    Deleted member 4120
  17. obisk
    obisk New Member
    Kalsruhe
    I do not know now exactly what to do ... : (270 + / - 4% is that ok?
    I need a linear mono poti?
    plz help
  18. Deleted member 4120
    Deleted member 4120
    ....help
  19. Frakk
    Frakk Active Member
    328Coins
    You guys are worse than kids in kindergarten.... :D
    How do you think Thanos figured things out? He didn't have anyone to hold his hand and tell him exactly what to do and buy....
    He experimented with different parts and tested it himself! He also used common sense!
    270° or 300°, DOESN'T MATTER!
    Yes, SINGLE, LINEAR potentiometer!
  20. Deleted member 4120
    Deleted member 4120
    guys,
    why do I have to separate the mass from my wiper motor housing if my frame is conductive.
    (My mass in my wiper motor is the whole body)
