3dof, AC motor.
Discussion in 'DIY Motion Simulator Projects' started by vulbas, Jul 17, 2010.
  1. robervalllll
    robervalllll New Member
    42Coins
    Re: 3dof, AC motor. axes combined ?
    My question is this got a 1.5 in the AMC board Thanos and read right here
    forum in which I can adapt it with a frequency inverter and use a
    three-phase motor, mai s saw that I had to make a small additional circuits
    to turn the PWM signal into an analog signal, is that right? Can anyone
    give me some hints on which drive to use? any frequency inverter
    serves or has some specific?
    I'm sorry for bad English is that I'm using Google translator, rsrrs
  2. vulbas
    vulbas Active Member
    france
    1,103Coins
    AC motor, 6DOF
    la petite avancé du jour
    la suite samedi ;)
  3. wimpo`
    wimpo` Member
    metselaar
    nederland, twente, vroomshoop
    178Coins
    Do you think the lcd tv will hold when mounted like that, because my lcd tv has the same mounting hole's.
    And using these mounting hole's is the easier way to go :yes:
  4. Frakk
    Frakk Active Member
    328Coins
    I would definitely add more cross bars to make it more rigid. As it is right now the LCD mount will flex too much, then snap once it has had enough.
  5. robervalllll
    42Coins
    My question is regarding the weight of the TV 42 which is about 39 lb
    (18 kilos), to stop the displacement and the move would affect to some extent the
    platform , which you will use gear motor to move the whole thing? how many HP?
  6. wimpo`
    wimpo` Member
    metselaar
    178Coins
    well I guess the calculations needed for that are not so easy.
    you would have to take in the lever
    this would be the easy part but for example, when the simulator moves forward so does the weight.
    this is called inertia.
    the downside is that when it has moved forward, and it has to move backward in a short period of time then the motors will have to push approximately double the weight?
    so in short it depends, you would have to know where the motors are positioned and how the weight will move.
    this is what I know about it, if I where you i would go overkill.
  7. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    mounting holes are not enough, I'll make reinforcements for the tv moves the least possible
    tv weighs is 15kg
    I use three geared motors. 550w and 14rpm and 347Nm
  8. wimpo`
    wimpo` Member
    metselaar
    178Coins
    so 347nm will push 347 / 9.8 = 35,38 kilograms * 2.20 = 78pounds in this calculation the lever arm is one meter.
    The arm is placed directly on the motor.
    Then you would have to think about how long the arm will be (this affects you maximum travel angel).
    say 20 cm goes 5 times in a meter so 35kg * 5 175kg of power.
    but you probably want some more movement so you will place the motor closer to the pivot point of your simulator.
    this will mean that the lever arm, that is from the pivot point to the outer dimensions of your simulator will be shortened so the weight would be more.
    but as your platform will be balanced you will have the weight of your tv, frame, peripherals and yourself.
    15kg + 30kg + 20kg + 100kg = 165kg give and take.
    divided by 2 = 82.5kg (inertia not included)
    you have the advantage that when any simulated axis is used there are always 2 or more motors push/pulling the weight.
    worst case scenario, when you brake hard and all the weight moves forward, for a limited time the weight will be on one motor.
    but it should not be a problem, as the weight will move back.
    So i think your okay given my calculations. :5+5:
  9. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    thank you for the calculation. I am reassured. here is a map of the platform with the placement of the engines and the center of gravity. also a map of my cam
    I may be passing to 8cm for the cam
  10. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    aujourd'hui je me suis attelé à la realisation des support de la tv,
    la suite au prochain episode
  11. wimpo`
    wimpo` Member
    metselaar
    178Coins
    this looks a lot better.
    make sure that is will not move inside the frame, because any kind of movement to the bolts of your television will cause it to brake off as time passes.
    same forces lever and inertia apply so don't underestimate this force.
  12. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    allez on avance encore
    percage et entretoisage (hein, ca existe pas ce mot ? :lo:l )
    mise en place
    le support, il faut que je fasse une petite extension sur l'exterieur du cadre pour placer le 3eme moteur
    on renforce pour pas que ca plie
    voilà. j'avais soudé le tube de 80x80, mais je me suis rendu compte à la fin que je l'avais souder sur la mauvaise plaque :bad: j'etais un peu agacé :[ y'a falut que je recoupe et que je netoie la plaque qui devais etre utilisé pour autre chose..... la suite au prochain episode
  13. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    suite.......
    bon on presente le tube pour voir
    la coulisse coupée et fixer sous la partie mobile
    la partie fixe est coupé à la bonne longueur, en fait un peu plus long pour les test, ce sera reduit de 5cm. un moteur est en place et on voit les support qui vont sous le moteur pour permettre à la came de passer
    un 2eme moteur est placé
    soudage de la petite extention pour le 3eme moteur
    presentation avant perçage
    sur cette photo on voit que c'est un peu haut, je vais reduire les tubes de quelques centimetres.on va y arriver ;)
    on va y arriver ;)
  14. robervalllll
    42Coins
    Vulbas am following its construction from the beginning, the very good
    photos, excellent construction of the project, excellent reliability solder, you're
    Congratulations, it will be a great 3DOF, can not wait to see working, if
    can put the project details, engine power, controller card
    etc.. I hope very soon be building mine too, I'm quoting the
    price of inverters and motors.
  15. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    helloo robervallll and thank's
    my simulator is the same of riton http://www.racingfr.com/forum/index.php ... try1014784 i use ac motor : 550W, 14rpm, and 347Nm. the price of motor : 300€ the omron mini j7 : 130€ for control the omron i use the VM140 110€
  16. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    j'avais fais trois cames avec le trou de biellette à 10cm de l'axe moteur, je vous laisse imaginer le resultat :LOL:
    j'ai repercé à 5,5. il faut encore que je vois pour le ressort et trouver un truc pour reduire le jeux au max au niveau du pied, enfiler une chambre à air de rous de bouette, bien graissé ca devrait le faire.
    là les cames etait à 10, ca fait que le simu penchait de 20cm, à peu pres 30° c'etait enorme. je n'ai pas fait de photo avec les came relevé mais ca montait de 20cm.
    là c'est à 5,5cm, beaucoup plus raisonable
  17. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    a new video
    http://www.youtube.com/watch?v=n03apyG44iU
    i posted a new video with suspension
    http://www.youtube.com/watch?v=6mq_LJz6Iic
  18. Frakk
    Frakk Active Member
    328Coins
    Great job so far!
  19. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    thank you Frakk
    pour l'instant c'est des essais à blanc. à mon retour de vacances j'ajuste tout parfaitement et fixe tout parfaitement, avant de tout redemonter pour poncer et peindre (comme les teuteul pour les connaisseur ;) )
    pour fixer les reglettes j'ai fai comme tu as dit et ca a été impec. j'ai encore fais au plus simple et est simplement fais un trou un peu inferieur au diametre d'une vis à bois, ensuite j'ai vissé direct. j'ai fais comme ca pour la planche du bas et aucun probleme.
    je vous mets deux trois photo :
    ici c'est les reglettes en alu, une barre de 2 metres débitée...
    j'avais fais le support volant pour me changer les idées ;)
    ici j'ai ralongé le tube qui coulisse de 4.5cm
    les reglettes en place
  20. RaceRay
    23,892Coins
    Great work, nice to see that things are moving. :) Please be aware, that sometimes free image hosters delete pictures or change the url´s of them. If that happens no more picture of your project are any longer available and viewable at x-simulator. Therefore I suggest to upload any project relevant picture with the attachment function of the forum.
    Br
    René
