3DOF for the Motion Flight Simulator
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by hunijjang, Feb 2, 2015.
  1. hunijjang
    hunijjang She is my wife :) Gold Contributor
    Operator
    Seoul, Korea
    1,164Coins
    @noorbeast Hello. :)
    How is the better than single shaft or dual shaft for 12v dc 250w motor(50rpm and 60:1 gears ratio and max 28A) + worn gear head?
    154,732Coins
    +11,194 / 57 / -2
    Can you please post a photo or link to what you mean.
  3. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    @noorbeast Hello.
    Sorry, I ask question again. :)
    If I attached potentiometer to the output shaft, single shaft or dual, what is the good choice?
    also How many people use a dual shaft? I would like to know the advantages.
    and If I have to use a dual shaft then It Does helps the COG balances of caculation?
    I'm thinking trying to make a birch plywood frame 30T and 2 pieces.
    In addition, two seat is somehow seems to be not good this point.
    Perhaps I thought might lead to smaller rooms... ;)
    154,732Coins
    +11,194 / 57 / -2
  5. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    @noorbeast Thanks Yes, those shafts. :)
    Sorry about that and I'll attach a photo URL links for simply understanding, be next question.
    154,732Coins
    +11,194 / 57 / -2
    Things like the motor specifications and cost are what is important.
    The pots can be attached to any shaft arrangements, so it is more about getting motors that are suitable for the design in terms of ratio, torque and speed.
  7. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    @noorbeast Hello. Thanks.
    Are you using the output from one shaft is equipped with couplings and a potentiometer?
    Thank you for your kind reply
    154,732Coins
    +11,194 / 57 / -2
    154,732Coins
    +11,194 / 57 / -2
  10. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello. @noorbeast
    Thanks for seeing to all these details and Sorry for that too lated my reply to you. :(
    I will start to making the my 3dof for flight motion simulator, by tomorrow.
    also, I'll update my sketch picture, tonight, I'll sketch for the what I actually wanted.
    I get a cold, so I'm in poor shape. one´s nose runs and have a fit of sneezing. :(
    See you again and Have a Great day to you. :)
