3dof---jazzy wheelchair motors---flight sim version
Discussion in 'DIY Motion Simulator Projects' started by stanley johnson, Oct 14, 2022.
  1. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    748Coins
    Glad you have some new found ambition! When you get the balance correct you can probably move the linkage out a few holes on the motor arms too. Depending on how much power they have.
  2. stanley johnson
    stanley johnson Active Member
    Diesel tech
    Nashville
    82Coins
    Should I mount linkage at an angle or 90degrees? By the way I got everything moved and now my balance seem to be on point, will mount motors tomorrow after I here from you on mounting linkages, thanks for everything
  3. ChuckyP
    Chicago, IL
    748Coins
    Linkage should be 90 degrees with the motor levers parallel to the floor.
    I hope the results are better than before.
  4. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Big Big Big Thanks to everyone who helped me to get this far, I love this rig, still got some tinkering to do and a fresh paint job at the e
  5. ChuckyP
    Chicago, IL
    748Coins
    You’re flying man! Awesome job. I can’t wait to see the finishing touches.
  6. stanley johnson
    Diesel tech
    Nashville
    82Coins
  7. stanley johnson
    Diesel tech
    Nashville
    82Coins
    @noorbeast i paid for the 2 years of plugins but all the download links are grayed out and want let me download, is there something I need to do after I purchased it?
    153,884Coins
    +11,154 / 57 / -2
    It takes a little processing time after purchase, @RaceRay can check the status for you when he has a spare moment.
  9. stanley johnson
    Diesel tech
    Nashville
    82Coins
    @noorbeast is there any way to take the slop out of my rig, what I mean about slop is the movement of the arms at motor before the motor actually turn, it causes my motors to move trying to adjust for the weight shifts on left of right motor I can feel it
    153,884Coins
    +11,154 / 57 / -2
    How bad is it, this is about average: https://www.xsimulator.net/community/faq/wormdrive-backlash.293/
    The longer the leavers the more pronounced backlash is.
    Potentially you may be able to shim the gears in the wormdrives.
  11. Dontmocme
    Dontmocme New Member
    66Coins
    Looks great, glad you could sort it out. What motors did you upgrade to?
  12. stanley johnson
    Diesel tech
    Nashville
    82Coins
    My first set of motors was jazzy wheelchair, my second set were also jazzy wheelchair but stronger ones but they have a little more lash then I like, my plan is to build me some sfx100 linear actuators to replace my front two motors
  13. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Hey guys I have a question, I built a wind sim using Arduino uno rev3 and Adafruit motor /stepper/servo shield. Like a lot of other people I can’t get simtool and simhub to work at the same time, so I would like to use the parts I already have with simtool dash speed fans, can someone show me how to do that. Also can I add the code that’s been used with setups on here to the same arduino? Do I have to buy another arduino? I’m using simtool v3
