4Dof-Controller code for arduino mega for AASD-15A and similar driver
Discussion in 'SimTools compatible interfaces' started by cubexxx, Mar 19, 2020.
  1. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Hello @d4m, I have succesfully running your V2 sketch and it works like it should. But have problem with, the rotation of the motor that only move 1 rotation. My actuator is 100mm travel from bottom to top.
    Can you give me idea? I want to add more info but I can give you if you need to.
    I'm using P100S driver though.
    EDIT:
    Found the problem already. Have to figure it out FA-11 on the driver.
  2. Nujj
    Nujj New Member
    USA
    317Coins
    Is the code compatible with version 3.7 of Flypt Mover?
