Question 6 DOF 24V DC 700W Wormgear Motor
Discussion in 'DIY Motion Simulator Projects' started by Jürgen Schon, Jan 13, 2019.
  1. George Amemiya
    George Amemiya New Member
    294Coins
    Good to know everything is working now !! hug::thumbs:thumbs
  2. Jürgen Schon
    Jürgen Schon Member
    57Coins
    Sim is working
    A Video of Output testing.
    no this is not fullspeed
    For Testing
    nolimits2
    1% of intensivity
    50% of posibile axis way
  3. _Gus
    _Gus Member
    406Coins
    Are you sure the rods you're using are large enough? Perhaps it's part of the design I've missed but they look bent.
  4. George Amemiya
    294Coins
    Woow :eek:!!! It looks insane !! I saw the whole platform off the floor on the first video ... NICE !!:cheers A little tweaking and you're good to go !!! Great work !!
  5. Jürgen Schon
    Jürgen Schon Member
    57Coins
    yes i bent it :rolleyes: i started the rig without any limits. so the leveler bent the rod.
    But they are strong enough. M16 Steel Rods. (16mm)
  6. Jürgen Schon
    Jürgen Schon Member
    57Coins
    Yes it goes off the floor :D but its even worst with a passanger inside.. At the first test the rig nearly fliped over ^^
  7. Jürgen Schon
    Jürgen Schon Member
    57Coins
    New Problems...
    Roll
    Pitch
    Heave
    works great
    Yaw
    Sway
    Surge
    works in the wrong direction?!
    Whats wrong with my settings?
    https://youtu.be/aLUIcAmO2zU
  8. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,052Coins
    3DOF, DC motor, Arduino, 6DOF
    Can you just use the FLIP checker to change the direction of a force?
    Maybe this is different from linear actuator.
  9. Rifly
    Rifly Member
    freelance photographer
    Latvia
    232Coins
    Hi, how are you doing? Im inspired by your rig, plus you have listed lots of info on parts so I want to make myself same one. Can you update us on your build?
    154,750Coins
    +11,196 / 57 / -2
    You may have to wait a bit for a response, as @Jürgen Schon has not been around since late March and may be busy with other things at the moment.
