6dof dc 24v smolka zigzag49
Discussion in 'DIY Motion Simulator Projects' started by zigzag49, Oct 13, 2015.
  1. MauroM3
    MauroM3 New Member
    Tecnical Consultant
    Canoas - RS - Brazil
    338Coins
    2DOF, 4DOF
    Amazing job, congratulations.
    I was see the 6dof working with big motors, but now I see the answer to my question.
  2. zigzag49
    zigzag49 Active Member
    724Coins
    Prompt @
    You're right it seems to a motorcycle curve, I think it comes from mixing roll and traction loss.
    Thank you Mauro M3
    If you can take big engine that will give you more feel and will last you longer
  3. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    I'm working on a flight sim that basically uses a drive shaft mounted to a chair for it's roll. I'm not looking for 360 degree rotation, but rather more like 180. Try to picture a steel bar running through a series of pillow block bearings. On one end a sprocket driven by a chain, driven by a motor (or maybe even direct drive to reduce backlash), and on the other end my chair. Everyone is recommending AC motors 750w and larger, but the current required scares the hell out of me..not to mention they seem really complicated to control via PWM even with a VFD. The business end is pretty light (like I said just a chair, joystick, and a skinny las)...Does anyone know of a geared DC motor that packs the punch to do this job? I've done the math, granted it might not be correct...but roughly 250nm seems like it could/should do it. Any input would be grrrreatly appreciated.
  4. michto35
    michto35 Member
    france
    102Coins
    Very nice work, your simulator is compact, highly responsive, beautiful challange for a 6 dof
  5. zigzag49
    724Coins
    Thank you michto.
  6. lujanie
    lujanie New Member
    96Coins
    zigzag49, amazing job!
    congratulations
    I think it will be an inspiration for my future project
    just one question: what is the feeling with traction loss? It's similar to real one?
    if you have some free time, could you make a video about that movement?
  7. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    That's an inspiring build. I didn't think it was possible to build such a small and compact 6dof.
    Well done.
  8. zigzag49
    724Coins
    thank you.
    At the moment the simulator is a new seat configuration mover, I just do a little video with the loss tensile any mobile there is a good feeling.
  9. Nuri KAHRAMAN
    Nuri KAHRAMAN New Member
    Istanbul
    276Coins
    This is amazing work.
  10. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
    @zigzag49 i was viewing your thread for one more time and every time i want to ask about the suspension. can you show with a video how the suspension works in action? i am curious how it works with surge and sway effect
  11. zigzag49
    724Coins
    Hi
    Sorry I board not have time to make a video, the shock absorbers have been removed because I do not need are being given it're mover seat configuration. I remake this video Weekend for traction loss that was asked.
  12. Zyadox
    Zyadox New Member
    196Coins
    Zigzag49, this is a truly inspiring build! :D You have given me hope that I can fit a 6DOF sim in my studio apartment space. I see that you are using rather small threaded rods and connectors to your DC motors. Do you believe the 24v motors and PSUs you've chosen could handle a larger degree of motion with a similar load to what you currently have, if we were to lengthen the rods and their connectors to the DC motor?
    I ask because it seems that your build is very conducive to driving simulators, but wouldn't offer too large range of motion when it come to flight simulation. I think I'd like to adapt what you've made into a compact flight sim, but would need to modify the sizes of the rods a little. I'm not sure if that would demand too much of the motors though.. Also I may go the JRK route to save on needing to wire and code too much.
  13. zigzag49
    724Coins
    Hi
    Sorry I did not see your message earlier suddenly I answered you're on your post.
  14. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    J'ai étudié avec Zigzag49 ce concept.
    Il est probablement possible d'allonger un peu les manivelles et les bielles.
    Mais dans tous les cas les courses maximales ne pourront jamais dépasser 15cm sur chacun des axes (10cm ici).
    Ceci avec des moteurs de 16Nm de couple et une partie mobile en charge inférieure à 100kg.
    I studied with Zigzag 49 this concept.
    It is probably possible to lengthen a little cranks and connecting rods.
    But in all cases the maximum racing will never exceed 15cm on each axis (10cm here).
    This along with 16Nm torque motor and a movable part load of less than 100kg.
  15. zigzag49
    724Coins
    Hello
    Installing arrears pregnant I had not yet asked.
    A little work has certain place wood because it was rotten.
    • Like Like x 9
  16. momoclic
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    Du travail de pro !
    Working pro!
  17. zigzag49
    724Coins
    Merci maurice.
  18. zigzag49
    724Coins
    A simulation of video in seat mover.
    [flash width=425 height=350 loop=false flashvars=]
    • Winner Winner x 3
    • Old Old x 1
  19. noorbeast
    152,571Coins
    +11,087 / 56 / -2
    Great job, your compact 6DOF looks to be really responsive and carries the load really well :thumbs
  20. zigzag49
    724Coins
    thank noorbeast;)
