6dof dc 24v smolka zigzag49
Discussion in 'DIY Motion Simulator Projects' started by zigzag49, Oct 13, 2015.
  1. zigzag49
    zigzag49 Active Member
    724Coins
    For the simulator in its current configuration, I do not ais need more powerful it asser cup my vertebrae:grin
    The day I will change it will be for another project;)
  2. mirxtrem
    mirxtrem mirxtrem.apps
    Electrical engineering student
    Colombia
    312Coins
    Amazing work, i lked because is very compact.
    Congrats
  3. zigzag49
    724Coins
  4. Fluke
    Fluke Member
    Stafford, United Kingdom
    822Coins
    Just read through this thread. Fantastic and very compact design.
  5. Fluke
    Fluke Member
    822Coins
    I am thinking of building something similar in design however I want to be able to lift and move about 170kg and build it using 350w motors and use steel instead of aluminium.
    Would 350w motors be able to lift and move that sort of weight. Here are the motors I was thinking about using.
    Reference MOT350W
    Engine 350w 3000 rpm
    Torque output motor 1,1NM
    Reducer with oil bath, ratio of 50
    Output torque 40NM
    Speed 60 rpm
    https://simukit.com/moteurs/8-moteur-350w.html
  6. Wanegain
    Wanegain Active Member
    Bruxelles
    2,007Coins
    If you use springs it can be done easily. It also depends on the lenght of your cranks.
    With only 3 motors and 3 springs there is almost 160kg on this one (cranks are 60mm) :
    • Dislike Dislike x 1
  7. SeatTime
    Nice video - lots of smiling faces :thumbs. The following is just for info and something to be aware of when building a 'simulator'. if you use springs be aware that just like a car they will introduce oscillations/unwanted movement at certain (normally high) speeds which causes the simulator to not move in a realistic manner Ie. Not tracking the data that was actually sent from the computer. Just like a car these can be tamed with dampeners - unfortunately installing dampeners also bring their own issues - which I'm very aware of as I originally used them on my simulator and later removed. Not trying to knock anyone's build - just trying to educate the community that using springs also comes with disadvantages, not just the advantage of offsetting load.
  8. zigzag49
    724Coins
    For a 3 dof in view of the capacity of the engines and the weight to be loaded with the inertia, springs are a necessary security. For a dof not obligatory, how much do you plan to axes?
  9. Fluke
    Fluke Member
    822Coins
    Will springs really be necessary for a 6 dof using the 350w motors I mentioned above?
  10. Wanegain
    Bruxelles
    2,007Coins
    We never took the time to do a six dof but normally the springs will not be essential although advised (at least 3).
    I agree with you @SeatTime, no matter what you are going to add to help motors this will involve unwanted effects. But with a properly configured PID you can greatly decrease these effects and do not feel them what is most important :thumbs
  11. marcusbeche
    marcusbeche New Member
    Brazil
    424Coins
    Congrats, @zigzag49 !
    What a great project!
