6dof master software modification
Discussion in 'Miscellaneous' started by MSK, Mar 18, 2012.
  1. Simon_lebel
    Simon_lebel Member
    Levis, Quebec
    147Coins
    2DOF, DC motor, JRK, 4DOF
    You have to upload a video!!! Congratulation
  2. MSK
    MSK Member
    53Coins
    Thank you Simon. Yes I will. I have to do some serious work within the next 24 hours. After that... I will try to make a decent video.
    Regards
    MSK
  3. jma747
    jma747 New Member
    Hello all,
    I´m building a 6DOF plataform using phidgets servo board with C++ Buider. I already read all vaiables from xplane and FS. Someone here could send me the source code from software developed by ROBIN on this forum. Its called 6dofmaster.
    I will try to do another possibility for user with other board.
    JMA747
  4. MSK
    MSK Member
    53Coins
    Hello Marcelo,
    I got your email. I am no C++ expert. There is a person in this forum called Tronicgr, probably you can see if he is free. He helped me with many of my problems. Here is the link to Robin's source code:
    http://www.mediafire.com/?5nxqi60h3nwjv9m
    I am currently pursuing other things and not working on this project anymore. Email me like before for communication as I may not visit this site. I hope you can complete your project.
    Best of luck :)
    Regards
    MSK
  5. MSK
    MSK Member
    53Coins
    Hello all,
    Just if anyone is interested to know where i made the joints in my overall system, I am posting this diagram:
    [img600px]http://img17.imageshack.us/img17/2167/designv.png[/img600px]
    Description:
    1. A plugin extracts gaming data from X-Plane and makes it available for Force-Sender.
    2. Force-Sender grabs the data and pushes it over the network to another computer which is running Force profiler.
    3. Force profiler is set up with 6 axis representing 6 parameters ( roll pitch yaw surge sway heave).
    4. Control software (modified version of 6dofmaster) reads from force profiler's memory, uses those 6 parameters to perform kinematics and gives us 6 output values for the 6 actuators. These values are in 8 bit binary. They are sent over the serial port(usb) to Arduino microcontroller.
    Credits:
    1. Creators of X-Simulator software.
    2. Creator of the X-plane plugin (Andrew Lancen)
    3. Creators of 6dofmaster (Robin Larabi and Arnaud Bobot )
    I must inform all that I am no longer working on this.
    Regards
    MSK
  6. RaceRay
    23,891Coins
    What a pity that we won´t see your platform moving.
    I assume softwareproblems are the main problems for stopping the project?
    I am curious if you ever tried out the 70$ software of http://bffsimulation.com?
    Regards
  7. jma747
    jma747 New Member
    Hi MSK,
    Thanks very much for your help. I will keep you informed ,as also here in the forum , my evolution on this project.
    As Raceray said, I will look on the BFF software. I already have read it, but I need some more time to get more information.
    Once again, Thanks a lot.
    Marcelo
  8. MSK
    MSK Member
    53Coins
    Hello Raceray,
    Well, I can't guarantee anything, but I will try to get videos of the platform in action once the new guys tune up the system and complete it.
    The software was a big issue, I tested with bff software. But I was looking for our own software. If you look at the system layout that I posted earlier, its just the kind of work you would expect from a noob...lol. I am no programmer so this was the way I worked it out. Too many links...lol.
    Regards
    MSK
  9. MSK
    MSK Member
    53Coins
    Hello jma747,
    You can try out BFF software. Its good. However, if like me , you want a customized software, you can check out Robin's source code.
    Regards
    MSK
