6DOF Work in progress
Discussion in 'DIY Motion Simulator Projects' started by beng2k, Jul 26, 2017.
  1. beng2k
    beng2k Member
    Ontario, Canada
    213Coins
    No I did not. Can you show on a picture where to cut as a see a few places that say that
  2. Thanos
    Electronics Engineer
    United States
    2,917Coins
  3. beng2k
    beng2k Member
    Ontario, Canada
    213Coins
    So I did as directed by the video. I verified no continuity between the 8bit side and center pins. Still this is the result
    Position 0-49 3.5v
    @ 49% it changes to 2.3 volts very rapidly
    It then has somewhat fine output until position 64 then stays at 1.1v until I hit 100
  4. beng2k
    beng2k Member
    Ontario, Canada
    213Coins
    Well I managed to get it to move. With me in it. Under my control! I setup the heave as DOF1 with heave at 50 and DOF2 as roll at 50 on all axis to test as I actually have no idea what I'm doing and trial by fire is kinda my way LOL
    All the actuators need to be better centered and some other small things but hell yes!
    Now some observations so far
    AMC doesn't seem to ever send 2.5v by my multimeter at positions 49 but sends close to 2.35 so I programmed the sabertooths to use that at input center.
    It's also PID 25/0/0, motor speed 30
    The actuator movement length is also only.about 50% of what it could be, how would I go about adjusting that.
    All in all I'm super stoked about it. But I'm now leaving my other half and I'm.not sure when I can work on it next until things are settled.
  5. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    That's so cool! It's moving so smooth.
    I have the same problem with actuator only moving about 50% of the full length they could. Either there is something to program in the Arduino program, or maybe add a potentiometer between the ground and 5v to change the range, I don't know. If you have a solution, please send it my way.
    "Leaving my other half", sound sad.
  6. beng2k
    beng2k Member
    Ontario, Canada
    213Coins
    Sad yes. Never easy but just isn’t working anymore.
    I’m wondering if it was something to do with PID or motor speed but I’ll look into next time.
    A little noisy due to the ball bearing guides and one arm is slightly binding but thank god it moves.
    Getting closer and closer
