A few questions before I start my build
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by getti, Feb 27, 2015.
  1. getti
    getti Currently building my first 2dof seat mover...
    Canada
    45Coins
    Hey guys,
    So now I got it all wired up and I uploaded the @RacingMat code. The motors spin continuously but the pots don't do anything. What am I doing wrong?
    153,764Coins
    +11,149 / 57 / -2
    Not my area of expertise but I would think you need to give more details about what you have or have not done, like installed drivers and tuned tolerance level, or not?
  3. getti
    Canada
    45Coins
    I installed the arduino drivers and set the baud rate as per the instructions. Then I uploaded the code and the motors started spinning. That's all I could figure out.
  4. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    @getti I know zilch about Ards but I imagine that the pots should be set to 2.5v which is the mid and stopped position. Use a multimeter on the center/slider position on the pot and set to the right voltage hope that helps. Good luck!!
  5. Linkup
    Linkup Member
    Graphic Designer
    Sweden
    855Coins
    Isn't the first thing that happens is the motor controller turns the motor until the degrees of rotation is meet for a total of 180°. 90° forward and back then it sets at 0° and awaits for input from SimTools? There are definitely other ways to do it and I just read someone explaining this, but it could be for another interface. Note that if POTs are readers then they can't read anything if they are just sitting on the desk? I'm about to start testing the same thing and have been reading a bit about it this morning.
    Edit: Noorbeast posted the related bits below.
  6. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    Can't quite see but I think you have the wiring from the pots into A1 and A2 on the arduino, They should be connected to A4 and A5. At least that is how they work on my rig using racingmats code. If I remember correctly there are two different wiring suggestions from Racingmat on different threads one saying A1 and A2 and the other A4 and A5
    Also if it is wired correctly the two led's on the mm will turn off and on as you turn the pot, middle off, clockwise or anti-clockwise on.And it is vitally important to get the pots to rotate in the correct direction when attached to the motors otherwise the motors will spin non stop.
    Hope that helps
    153,764Coins
    +11,149 / 57 / -2
    I don't use the code but @RacingMat states the following:
    The code is written to put the simulator on middle position at start :
    /* init position value*/
    int DataValueL=512; //middle position
    - if your pot is fully turned to max, as Arduino reads potentiometer value as motor position, Arduino believes that motor is in max position.
    - but the order is to be in middle position
    - so the Arduino will ask the motor to go reverse in order to go to middle position
    - your motor is turning
    - but while your pot keeps still, the motor will turn non stop !
    - when you manually turn the pot backward to min, Arduino reads that motor is in min position
    - but the order is still middle position, so Arduino will tell the motor to go forward
    - motor runs non stop until the pot is in middle position
    In the code, you have a tolerance parameter : when the pot is around middle position (<middle+tolerance and >middle-tolerance), the motor stops.
    You can broader Tolerance value to stop your motor more easily manually.
    • Informative Informative x 4
  8. getti
    Canada
    45Coins
    The wiring diagram is pretty clear and it says pots on A0 and A1. Pretty sure the reason both lights are on is cause it's spinning continuously in one direction no matter if I turn the pot.
    • Disagree Disagree x 1
  9. getti
    Canada
    45Coins
    I can't see any Tolerance value in the code. Also I tried changing the rotation values but it doesn't seem to do anything. I have no idea what I'm doing when it comes to this code stuff. Greek to me...
  10. Linkup
    Linkup Member
    Graphic Designer
    Sweden
    855Coins
    I'm assuming this is it. I'm completely new to this type of code also.
    int Tol=20; // no order to move will be sent to the motor if the target is close to the actual position
  11. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    The code works (for testing reasons) without simtools.
    You don't even need to connect the arduino to your computer with a usb cable...you just need to power it with its own psu(9volt 1000+maH preferably).
    In this configuration the arduino tries to put both mottors in the middle position.
    If everything is connected as required the motors start spinning until you set both potentiometers in their middle position.
    Then the motors stop.
    So if both your motors spin...then you are OK with the motor connections.
    But if they don't stop or change direction when you turn the pots...then there is a mistake on the pots connection that you need to correct.
  12. pipis2015
    Athens, GREECE
    10,248Coins
    Did you try A4 and A5 analog inputs?
    Should solve your issue.
  13. getti
    Canada
    45Coins
    SOLVED!!! Thanks for that. The wiring diagram should be updated for @RacingMat code to show analog A4 and A5.
    So what's the next step to get the interface working with simtools?
  14. getti
    Canada
    45Coins
    Got everything working on the model, thanks for the help everyone. Still have to figure out what a "profile" is but it seems to work pretty good for now. Also planning to add traction loss to the model but I might start building the full size rig first.
    Here's a video: let me know what you think..
  15. getti
    Canada
    45Coins
  16. George Dobransky
    Hungary
    - 43Coins
    Hi getti,
    I'm George from Hungary.
    I'm also just want to build a seat mover, as you did.
    I have already the motors, and the PSU's. I have read your posts about the building,
    I have understand almost everything about the mechanical part, but at the electronic
    installation maybe I need some help.
    So. I need the followings, right?:
    UNO R3 ATmega328P CH340G USB Driver Board for Arduino DIY
    also I need:
    Dual VNH2SP30 Stepper Motor Driver Module 30A Monster Moto Shield Replace L298N
    The UNO R3 unit connects to the PC and simtools by USB?
    The Stepper Motor Driver connect to the UNO, and connects to the motors, right?
    The power from the PSU's connects to the Motor driver, as in your pics?
    The Motor Driver's output connect to the motors, but I can see some other connections to the motors
    just at the end of the rig, maybe the pot. meters?
    If I need pot. meters, what kind of them I need?
    Can you send me a complete wiring of the final working unit?
    Many thanks for help me.
    George, Hungary.
  17. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Please start your own project thread here and re-post your questions on it, not on another member's build thread: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    I sound like a broken record :(: https://www.xsimulator.net/communit...tion-loss-wipers-arduino-mm.8904/#post-114816
  18. George Dobransky
    Hungary
    - 43Coins
    Hi Getti,
    Should you show me the final and working diagram for wiring or some link for that?
    Thanx,
    George
