Question ABOUT IBT2 12v or 24v
Discussion in 'DIY Motion Simulator Projects' started by Doga Darko, Jan 19, 2024.
  1. Kevinski
    Kevinski If it doesn't fit, hit it until it does.
    Jack of many trades, mastering some.
    Australia
    435Coins
    @Doga Darko Yes! I agree Darko. Exploration is very important for growth. Good luck mate and keep us in the loop!
  2. Stefzouille
    Stefzouille Member
    595Coins
    2DOF, DC motor, 4DOF
    Hello friends, tell me,
    I don't know what to do, are you experiencing problems with the I BT two with the engine humming non-stop with jerks as soon as you turn it on without moving?
    The only way I found was to lower the pwmmax, but as a result the engines no longer move.
  3. Antonio1986007
    Antonio1986007 New Member
    - 94Coins
    Hello, do you have everything correct in the smc3utils graph? Have you checked that the connection of the potentiometers is correct and has no errors?
  4. Stefzouille
    Stefzouille Member
    595Coins
    Hi @Antonio1986007
    So by adjusting a little I managed to eliminate the noise. The problem is that the chassis is empty and when I put 40 kilos on it the noises start again and in the end, there should be around 150 kilos on it so I'm a little doubtful.
  5. Antonio1986007
    - 94Coins
    I think what noise are you talking about, it happens to me sometimes too, but it's just noise, my motors don't shake, as soon as I get on or start playing it stops doing so, I've had several motors, potentiometers and sensors with various configurations simulator and it has always happened to me, but in my case it doesn't affect anything
  6. Antonio1986007
    - 94Coins
    I also have the metal structure insulated directly to ground and ferrite in the potentiometer cables. If there is anything you don't understand, let me know. I'm using a translator
  7. Stefzouille
    Stefzouille Member
    595Coins
    no it's perfect, for me it moves sometimes and the motors growl... I'm waiting to finish the installation and I'm waiting for the parts, and I'll make a better pid, well I'll try to do it. the ferrite I will test thank you ^^
